Author Topic: Motor and gear reducer assembly  (Read 309 times)
Online kelLOGg
« on: July 29, 2019, 06:07:11 AM »
I have read, understand, and agree to the terms of posting an ad on the Forestry Forum.
I built a sawhead advance system consisting of a small DC motor and gear reducer. As it turned out it was underpowered for my mill so I replaced it with a more powerful unit so now I am offering the original for sale for $100 or best reasonable offer plus shipping. (Unit weighs 23 lbs)
Here are the specs:
Motor is made by RAE Corp, 12 to 24 VDC, 1750 – 4200 rpm, torque 2.56 in lbs.
Gear reducer is made by Brother, 100:1 gear ratio, model SP HOB-9269
Unit measures 16.5 inches long and pivot points are 8.5” apart.
Sprocket measures about 1.75” dia and accepts a #40 chain.
It could be used as is or disassembled and repurposed for a sawhead advance or a head lift depending on weights involved.
(As manufactured the gear reducer has a vent hole which I thought would admit water if it rained while milling outside so I inserted a copper tube to prevent water entry.)
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Inline Helical gear reducer
Started by Fla._Deadheader on Wanted
Last post October 12, 2009, 10:38:39 AM
by Fla._Deadheader
What oil type for power feed gear reducer?
Started by hunz on Sawmills and Milling
Last post May 18, 2013, 07:42:42 AM
by Al_Smith
gear motor
Started by gary on For Sale
Last post July 24, 2009, 01:16:32 PM
by gary
Some Assembly Required
Started by Patty on General Board
Last post April 22, 2012, 01:11:24 PM
by customsawyer
