Author Topic: dynamic or static tension  (Read 927 times)
Offline Pabene
Re: dynamic or static tension
« Reply #20 on: August 05, 2019, 07:31:36 AM »
Belleville washers are good. You have to use a number of the washers so the package of washers will be about 3 " long. The spring function in this washers is rather steep, the force to compress a washer increases quickly. You can also adjust the compress force with this washers by to put them together in the package so two (or more) is turned back to front, next group front to back and so on, it will dubble the force. To have an suitable function in your mill you need a remaining springstroke of 0,5" when you have the blade under tension.
Offline Steve Crook
« Reply #21 on: August 05, 2019, 09:52:21 AM »
      the spring I got from cooks is a 133-012 spring bandmill yellow 1400 lb. there cost was 30.dollars. I made a holder for a digital caliper that covers 2 foot. on my thought that it will be more  accurate over a longer distince than the ones that span a fiew inches.
     yes I am still in the Helena area. Are you in The area on our fires?
Offline charles mann
« Reply #22 on: August 05, 2019, 12:39:51 PM »
@MAF143 if you don't mind, maybe a part number for them and ill do a google search and see if i can come across something online to see if it would work for me. thank you for the info.
@Steve Crook thanks for the p/n, once i get a more accurate requirement for my blade, ill try the different recommendations and se which will work best.
naw, not up there, stuck in colorado again this yr. our sister ship is based out of helena, but is in missoula right now. if i end up on that machine next yr and we actually start our season off in helena, ill give you a shout and try to swing by.
Temple, Tx
Offline MAF143
  • Work hard, Play hard
« Reply #23 on: August 05, 2019, 03:28:37 PM »
If it isn't raining when I get off work, I'll walk out to the mill and get the manual and some info for you.  Unfortunately the thunder rolls at the moment...
I'll take the calipers and get some measurements and pix.
scuba-smiley electricuted-smiley
Always having a great day!
MS 391, MS 250, HM-126, Ferguson TO-35, '97 Ram 1500 wood cuttin' truck, splitter, Woodland Mills Grindlux 4000 sharpener, Vogelzang Ponderosa keeping us warm
Offline MAF143
« Reply #24 on: August 05, 2019, 05:03:08 PM »
Kinda glad it was raining.  Even better info this way all except the thread dia and pitch.
Woodland Mills has the Operators manual on their website.  Pages 57 and 68 have nice diagrams of the belleville (part 164 in the list) washer stack and the parts list is in there too.
There are other washers and a thrust bearing in the build stack for the tensioner too.  Tension handle is part 20 but doesn't give the threads.  Blade info is part 46.  Part 19 tension bar doesn't give the thread size or pitch either.  I would think the thread size and pitch along with the 25 #' of torque for that blade size info would get you to a close starting point for your build.  Sounds like you've been wading into the math way deeper than I've looked into.
I'll try to get over to the mill later and get that thread info for you.  Suspecting 18mm or so and probably a standard pitch.
Not a whole lot of free space under the spring once tensioned, but it works well, more like .05" instead of .5"
Offline MAF143
« Reply #25 on: August 05, 2019, 05:53:26 PM »
Still sprinkling a little, but the sun is out.
The threads to tension the blade on this mill are 3/4-10  surprised me since everything else is metric.  Hope this helps you out.
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #26 on: August 05, 2019, 06:56:05 PM »
Dont know that much about the physics of what has been discussed here.
I crank my WM LT40 till the needle is nearly vertical and saw.
I'm thinking that the V belts on the wheels must take care  of any instant increase in tension due to  a chip or piece of bark engaging the wheels.
Works for me.
I guess the Cooks steel wheels are spring loaded to accomplish the same thing, Is this an accurate assumption?
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
« Reply #27 on: August 05, 2019, 10:53:15 PM »
@MAF143
thanks, ill take a look see on their site.
Temple, Tx
Offline Pabene
« Reply #28 on: August 06, 2019, 04:24:30 AM »
Petefrombearswamp, You describs the function very good. I have steel wheel in my mill and would like to add a springpackage, unfortunatly it is complicated to do in my mill. I protects my mill by a skraper as acts as a guard against sawdust and bark between blade and wheel.
The reason for me to suggest a longer spring package is that it would give a more linear tension force during the movement from a heated blade or instant pinched bark. That way the blade will survive better. I like bellewille washers as it is a lowcost solution, if you would end up in a too low force you can just rearange the package of washers insted to buy a new expensive toolmaker spring.
I have experiance from Pilous saw mills with Bellewille washers in the tension system. I have checked the tension on a lot of Pilous mills with my tension meter. The tension are equal, within few percent, from mill to mill. Insted of a torque wrench they use the length of the compressed package as is the reference. It will give you a higher accuracy as the variation in friction in the threads is bypassed.
Woodmizers spring solution with a airfilled rubber ball looks also good, I think it meets all you need.
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« Reply #29 on: August 06, 2019, 07:57:47 AM »
granted a hydraulic ram (port-a-power, or short stroke horizontal bottle/floor jack) with a psi gauge could greatly minimize the need for using the tensionmeter, but its 1 more thing to worry about, throwing a temper tantrum and sending very sharp things at very high speeds everywhere. but so could a spring, which is why I'm asking is dynamic would even be a logical method of tensioning.
A hydraulic ram is what tensions my Champion mill.  The ram has a pressure gauge on it, and as long as I keep the pressure close to my optimum number, all works well and has been for eleven years with no shrapnel or other bad things happening.
When I got my mill I learned about band tension, strain vs psi etc.  I then clamped a vernier across the band and tensioned to see what pressure got me the correct strain.  That's the psi that I run ....
cheers
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Offline JoshNZ
« Reply #30 on: August 10, 2019, 07:08:17 PM »
Probably better to go in this thread than my build sorry Charles XD
I only skimmed it sorry if it's been said but how does one go about tapping the cylinder of a jack? I did pull the top off one at home here, the outter wall is not the cylinder wall it is the reservoir and the cylinder is nested inside that. So you would have to drill the wall, and cylinder, tap the cylinder, screw in the output nipple then weld or seal the nipple to the outter wall somehow?
Has Arnold been around here lately I wonder how he did his? Am I on the right track?
Also.. could you force the cylinder to hold a wee pocket of air as a spring/dampening system or are they designed to bleed this out when you let up?
« Reply #31 on: August 10, 2019, 07:35:56 PM »
@JoshNZ
I think the drilling of the cylinder was explained in a sub link to a link provided, i think maybe on page 1. Ill look when i get off tonight. Iv got 5 web browsers open, with 3-6 pages per window. You might find it faster in you go the provided link and read through it till another link is posted. Its either in the sec link or another link provided within the sec link. Just gotta read through the stuff like did and stumble across the info.
Temple, Tx
« Reply #32 on: August 11, 2019, 01:57:13 PM »
@JoshNZ here are the links i read through.
Wm spring blade tensioner conversion in Sawmills and Milling
Tensioning method for homemade bandsaw mill in Sawmills and Milling
Hydraulic Tensioner in Sawmills and Milling
after sign through these, plus what others left on my thread, i found the info i was looking for. now i just have build it in a way that will work on my set up.
Temple, Tx
Offline JoshNZ
« Reply #33 on: August 11, 2019, 05:34:53 PM »
Are you referring to the post with the gauge tapped in the top of the cylinder? The cylinder is not full of oil in the jack I have here, the seal is at the bottom of it and the top has a threaded 'foot' as a means of taking up slack before you get the jack working which is great if it's used as a jack!
« Reply #34 on: August 11, 2019, 06:30:39 PM »
IDK, i didnt go into depth about the gauge on the jack bc im not going that route. I simply provided additional links that might yield info for you. I did see a gauge on a jack, dont remember which link it was and wasnt going to read through them to find out bc i didnt have the time and i wasnt going that route.
Im sure there is something within those links or links within those links that might be beneficial for your purpose.
Temple, Tx
Dynamic Duo
Started by sawdusty1 on Chainsaws
Last post August 09, 2013, 10:43:09 AM
by sawdusty1
Demo day - Dynamic's Cone-Head chipper
Started by Bibbyman on Forestry and Logging
Last post June 29, 2006, 07:24:55 AM
by Burlkraft
static phase converter
Started by kelLOGg on Drying and Processing
Last post July 14, 2007, 10:47:40 AM
by Gary_C
Non-profit in Georgia wants old sawmill, or parts, for static display
Started by Okrafarmer on Wanted
Last post January 17, 2016, 12:07:15 AM
by Okrafarmer
