Author Topic: Circular saw blade  (Read 389 times)
Offline Waterford Woodworks
Circular saw blade
« on: August 08, 2019, 04:42:05 PM »
 So I came across 3 of these blades and am trying to figure out what they would go to. They are 54” in diameter and 7/16” thick. Any one have any ideas?
2006 Lt40 Super Cat 51, Allis Chalmers 185
"Keep doing what your doing and you'll keep getting what your getting, life is what you make of it."
Offline goose63
Re: Circular saw blade
« Reply #1 on: August 08, 2019, 05:54:10 PM »
Are thy buzz saw blades ?
goose
thank you to all the vets
Offline Gearbox
« Reply #2 on: August 08, 2019, 08:09:57 PM »
They are cross cut saws of some kind . Maybe for trim sawing lumber bundles . Someone will know .
Offline moodnacreek
  • Sawin by the notches
« Reply #3 on: August 08, 2019, 10:17:56 PM »
If the teeth are not part of the saw body I would think they are for sawing steel or stone. Saws where made for both. For steel they would be much thicker [and small teeth of very hard material] than wood saws.
« Reply #4 on: August 11, 2019, 11:18:51 AM »
The tooth section looks like it could be separate from the center “hub” section. There is a fine line about 2 1/2” in from the outside of the blade that goes all the way around.
31-33" circular blade for swingmill or twin blade
Started by CaseyK on Sawmills and Milling
Last post June 10, 2017, 11:09:41 PM
by CaseyK
20" Circular Saw Blade
Started by musikwerke on Wanted
Last post February 13, 2008, 12:13:05 PM
by musikwerke
Circular blade heating up.
Started by 01frick on Sawmills and Milling
Last post November 11, 2007, 12:56:42 PM
by Frickman
circular saw blade maintenance
Started by chrisp on Forestry and Logging
Last post September 15, 2011, 12:00:41 PM
by beenthere
