Author Topic: Bundling Wood Shingles  (Read 250 times)
Offline bryantb2
« on: August 09, 2019, 08:44:35 AM »
After almost a year I have my old Perkins Shingle mill up and running and I have a good supply of cedar logs to cut into shingles. The only problem I am left with is how to bundle the shingles after I have cut them for storage until I am ready to use them. I am planning on using wood shingles on a couple of small out buildings that will be build this fall/winter. I would like to bundle the shingles and some how band them together to prevent them from cupping until I am ready to use them. What would be my best way to do this?
Offline moodnacreek
  • Sawin by the notches
Re: Bundling Wood Shingles
« Reply #1 on: August 09, 2019, 08:54:50 AM »
Somewhere I have seen a wooden form with a lever and press plate on top. It had slots to get tie wire around the pack.
Offline Oliver05262
« Reply #2 on: August 09, 2019, 10:52:32 AM »
A YouTube video titled American shingle company Warrenton, OR shows one way of bundling them at about 6:30 in the vid. I have seen a wooden frame of a box set flat on a low bench used the same way. The two guides in the middle let you place your one strap in the right place. Some one here on the forum also had a video showing his shingle mill and he bundled them like that.
"You can't do wrong by doing good"
It's OK to cry.
Split wood bundling machine
Started by moosehunter on For Sale
Last post August 22, 2011, 04:50:37 PM
by moosehunter
Wood shingles
Started by Bruno of NH on Sawmills and Milling
Last post July 30, 2018, 07:52:00 PM
by shinnlinger
Making and installing Wood Shingles
Started by Planman1954 on Sawmills and Milling
Last post April 23, 2015, 06:02:48 PM
by Peter Drouin
Wood for Roof Shingles (other than cedar)?
Started by MEMountainMan on Timber Framing/Log construction
Last post August 29, 2014, 09:56:41 PM
by Roger Nair
