Author Topic: Quick Introduction.  (Read 294 times)
Offline KeithGy
  • From IT to Farming. Couldn't be happier!
Quick Introduction.
« on: August 09, 2019, 08:39:51 PM »
Hey Gang,
Wanted to take a minute and introduce myself. My name is Keith and I'm from GA and recently purchased a Norwood HD36 (with 4 extensions). Lord help me it's manual (no hydraulics) but I hope to add hydraulics as quickly as possible :D
Currently I'm cutting some pine and cedar that I have (approx 200K lbs were dropped at my house from a logger friend). Seems some oversized storm wood needed a home and the local mills weren't interested in 36"x30' lumber.
I've been reading the forum for a couple of months and I grateful to all that post answers and all the photos. I look forward to (hopefully) becoming a friendly addition to the forum.
Sincerely
Keith-
Norwood HD36, Kubota Tractor L4701
Offline Southside
Re: Quick Introduction.
« Reply #1 on: August 09, 2019, 09:07:30 PM »
Welcome to the Forum, you Sir are a brave man!!
Offline thecfarm
« Reply #2 on: August 09, 2019, 09:34:38 PM »
Welcome to the forum.
No matter what you will need a Logrite cant dog or a peavey. Sponsor on the left and nice people. Those big ones are hand to saw. Meaning hard to turn,hard to get through the throat of the mill and so on.But they will yield some lumber.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: August 09, 2019, 09:37:54 PM »
   Welcome to FF. Be sure to update your profile with your specific location in GA. It will come in handy when you post questions and such. You can add your equipment list under you signature line which also helps. Which part of GA are you in anyway?
Offline KeithGy
« Reply #4 on: August 09, 2019, 10:28:46 PM »
I'm from Columbus area and a Logrite cant pole is on my order list. at this time I'm using my Kubota tractor with grapple to manage the logs. I have 14 cedar and the rest is pine (some small enough to manage and practice). I'm planning on cutting the 32-36" logs into 4' sections and slabbing. They were heavy enough to bog down a timberjack loader. The trucks came in WAY over weight and were unloaded on my land that's how I know approx weight (as opposed to BF).
Offline firefighter ontheside
  • I like trees.
« Reply #5 on: August 09, 2019, 10:47:48 PM »
Welcome aboard Keith.  Iíve learned a ton here and Iím sure you will too.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline Ea$y Money
  • I know enough to be dangerous!
« Reply #6 on: August 09, 2019, 11:58:38 PM »
Hey Gang,
Seems to be a sudden influx of Keiths from Georgia. I'm Keith from North Georgia and just brought my new mill home. Bought a Timberking 1400.
Hope to see more posts and pictures from your project. Welcome to the forum and congratulations on the mill!
The harder you work, the luckier you get.
Timberking 1400 w/Diesel engine and Setworks, IH 986, Kubota M5-091, Lincoln Pipeliner SA-250 Diesel Welder, F450 4x4 Chassis Cab, Lots of Stihl, Warn 8274 Winch.
Offline RAYAR
  • Retired May 2/19 more time to play with my mill
« Reply #7 on: August 10, 2019, 01:43:49 AM »
Welcome to this great forum, you know you're in the right place.
mobile manual mill (local build) (mods & additions on-going)
Shop built auto band sharpener
Husqvarna 50, 61, 254XP
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans
Offline Sixacresand
  • John and Nancy
« Reply #8 on: August 10, 2019, 06:01:55 AM »
Welcome to the Forum and congratulations on your new mill.
Offline LeeB
« Reply #9 on: August 10, 2019, 06:33:35 AM »
Sounds like he's fixing to learn 100 tons. Welcome Keith.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #10 on: August 10, 2019, 06:54:23 AM »
Welcome to the Forestry Forum Keith!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Quick Introduction
Started by ArcFault on General Board
Last post September 04, 2010, 02:37:18 AM
by SwampDonkey
New Member Introduction And A Quick Question
Started by DaveinNH on Sawmills and Milling
Last post August 12, 2015, 03:20:49 PM
by AnthonyW
Quick Fix
Started by Magicman on Sawmills and Milling
Last post March 24, 2015, 08:53:46 AM
by Magicman
A quick thank you!
Started by bo99 on Drying and Processing
Last post October 22, 2014, 06:12:52 AM
by red oaks lumber
