Author Topic: Woodmizer Lt15 blade roller heating up  (Read 170 times)
Offline Woodpecker52
« on: August 10, 2019, 11:02:16 AM »
I put on a 4degree band on my woodmizer Lt15 mill, It was a 1 1/2 inch wide instead of the 1 1/4 inch I normally use.  I noticed that the blade guide roller next to the drive wheel was hotter than the tension wheel side roller.  I think it was 190 degrees vs. 98 for other.  I used the same tension I always use, and when I switched back to 1 1/4 inch the roller ran about the same at 98.  My question is this normal for using a wider band all things staying the same without any adjustment to roller guides etc.  The last thing I want to do is start monkeying with adjustments. I also do not want to damage the rollers by running a wider band if it causes the roller to heat up.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Online Southside
Re: Woodmizer Lt15 blade roller heating up
« Reply #1 on: August 10, 2019, 11:17:38 AM »
I am thinking the band was applying more stress towards the outside of the roller and the bearing was not happy, just a theory. How wide is your roller?
Offline LeeB
« Reply #2 on: August 10, 2019, 11:22:52 AM »
Would not the wider bands have more overhang when centering up and the band wheels and therefor possibly be scrubbing the back flange on the guide roller a little hard?
« Reply #3 on: August 10, 2019, 11:29:24 AM »
The rollers were made for the 1 1/4 band the 1 1/2 inch teeth stand out and the front of the roller is hotter than the rear and I noticed the bolt temps are the same normal temps for both, so it is exterior heating from band vs any interior problem.
« Reply #4 on: August 10, 2019, 11:33:28 AM »
I guess I could get larger guide rollers but I really do not want to do that,  I was just shocked that there would be such a difference in adding 1/4 inch to a blade diameter.  I do not like the wider bands so far.
Offline Mike W
  • Location: Boundary Washington - Right on the edge of the Northern Boarder
« Reply #5 on: August 10, 2019, 11:36:50 AM »
Being the drive side roller is heating and not the tension side, have to lean towards what Southside mentioned, the distance from the drive side roller to the bandwheel is much closer then the tension side, seems the wider band is applying higher pressure at the front of the roller while the band is trying to stay centered on the bandwheel.  The tension side bandwheel to the roller may have enough distance from wheel to roller to allow a more balanced pressure to the roller.  Possible run the adjustment all the way out closest to the tension wheel side and test again to see if that roller heats up similar to the drive side roller?
my acme band saw blade (captive needle bearing )roller blade guide
Started by buildthisfixthat on Sawmills and Milling
Last post January 16, 2012, 09:34:15 AM
by 5quarter
ID Needed for Woodmizer Roller
Started by quadracutter222 on Sawmills and Milling
Last post January 26, 2019, 12:54:50 AM
by Woodpecker52
Roller blade guides?
Started by WoodChucker on Sawmills and Milling
Last post August 11, 2003, 10:58:11 AM
by Bibbyman
Blade roller question
Started by just_sawing on Sawmills and Milling
Last post December 04, 2008, 08:36:39 PM
by logwalker
