Author Topic: Question about homemade sawmills  (Read 224 times)
Offline hackberry jake
« on: August 10, 2019, 04:03:32 PM »
I am in the pondering stage of building a band saw mill. I read that recommended blade tension is around 13'000 lbs per inch. Assuming the teeth on a 1-1/4 blade are 1/4" high. That's 1" of blade. So the blade at the top and bottom of the wheel are tensioned at 13k lbs. That's 26k lbs of force pulling on each band wheel. That's like sitting a concrete truck on your mill frame. The standard semi-truck axle is rated at 20k lbs. Something isn't adding up to me.
Offline Hilltop366
Re: Question about homemade sawmills
« Reply #1 on: August 10, 2019, 04:31:18 PM »
Offline JEverettM
  • New to the forum and the sawmill.
« Reply #2 on: August 10, 2019, 04:58:25 PM »
From what I gather, blade tension is in psi (pounds per square inch), which isn't quite the same thing as lbs of force.
Say the cross-section of the blade is bout 1in x 0.045in (thickness), that's only 0.045in^2.
If the tension calls for 13,000 lbs/in^2 (psi), you'd have to multiply that by the cross-sectional area of the blade.
So 13,000lbs/in^2 * 0.045in^2 is only about 500 or 600 lbs of force.
In some of their videos online, Cooks saw mentioned that the spring in their tensioner is rated for 850lbs.
I'm new to sawmills as well, so I'm sure others on the forum can give you a much more in depth and educated answer.
Online charles mann
« Reply #3 on: August 10, 2019, 06:37:00 PM »
I also inquired about tis type of question in my thread titled dynamic or static and there are links in there, which after scrolling through those links, it was linked to another and another and another. I just read the links till i found most of the info i needed then a youtube vid about the same question, and he explained how to calculate the psi into ft lbs of force.
Temple, Tx
« Reply #4 on: August 10, 2019, 06:59:20 PM »
I didn't take the thickness of the blade into account. Thanks guys.
homemade cut off saw question
Started by paul case on Sawmills and Milling
Last post October 09, 2010, 11:17:20 PM
by paul case
Homemade bandsaw question
Started by Tyrin2saw on Sawmills and Milling
Last post August 20, 2011, 10:27:29 PM
by shelbycharger400
Homemade mill question
Started by Raider Bill on Sawmills and Milling
Last post April 03, 2012, 11:08:52 PM
by WDH
question
Homemade belt guard question
Started by kip on Sawmills and Milling
Last post March 25, 2003, 06:40:51 PM
by kip
