Author Topic: WM sharpener cam motor stall  (Read 387 times)
Offline marcd
« on: August 10, 2019, 07:49:54 PM »
Hello everyone i am new to the forum and have a question about an older WM bandsaw sharpener I just bought. I have started using the sharpener and everything works fine but once in a while the blade seams hard to push and the cam motor stops. When it is stopped if i move the speed adjustment the motor starts right back up again and runs fine for another while. So i wanted to know if anyone here had the same problem?
To my knowledge an electric motor usually have a lot of torque and should not have any issues pushing the blade but i dont know about this particular set up. Should i replace the motor or should i be looking somewhere else???
Any help would be greatly appreciated :)
Thank you
Online Sawmill Man
Re: WM sharpener cam motor stall
« Reply #1 on: August 10, 2019, 08:41:42 PM »
possibly a kink in the blade
"I could have sworn I went over that one with the metal detector".
Offline pineywoods
« Reply #2 on: August 11, 2019, 03:34:18 PM »
Crud on the back side of the blade where you won't see it. Clean blades before sharpening.
Notch worn in the roll pin on the end of the pusher arm, hangs on the backstroke.
Insufficient lube, water pump cloggs with grinder dust.
Offline marcd
« Reply #3 on: August 13, 2019, 07:34:04 PM »
Thank you very much for the replies i will be looking into this issue this week end as i will have more blades to sharpen. but i think you guys are pointing in the right directions since the blade was hard to install in the blade guide.
Thanks again and ill post this week ends outcome
Offline donbj
« Reply #4 on: August 14, 2019, 01:39:29 AM »
You may have the clamp pressure too high. I have the old drag sharpener as well and when it works too hard it quits til it cools for a few minutes. Anyway, two things to consider.
Woodmizer LT40HDG24
Offline woodyone.john
« Reply #5 on: August 21, 2019, 09:18:16 PM »
Mine does this sometimes.Worse when the oil and machine is hot and the advance speed is slow. I blame the circuitry but have yet to do something about it
Saw millers are just carpenters with bigger bits of wood
Offline Bandmill Bandit
« Reply #6 on: August 21, 2019, 09:30:52 PM »
ALL of the above,  PLUS a set of new brushes in both motors and a good cleaning of the motors helped mine get back to normal.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
Woodmizer sharpener motor control
Started by shopteacher on Wanted
Last post January 01, 2014, 03:04:52 PM
by shopteacher
question
Where to find motor for sharpener build?
Started by Delawhere Jack on Sawmills and Milling
Last post March 21, 2013, 08:04:34 PM
by Delawhere Jack
Cottonwood stall boards
Started by ElectricAl on Sawmills and Milling
Last post October 14, 2003, 06:48:36 AM
by Frank_Pender
lumbermate 2000 stall
Started by wfontjr on Sawmills and Milling
Last post June 07, 2012, 07:39:02 AM
by moosehunter
