Author Topic: Leveling a LT 35  (Read 367 times)
Offline Arkyrick
  • Doing it since 2008
Leveling a LT 35
« on: August 12, 2019, 08:28:16 AM »
Ok I've been told by WM  that the LT only has to be eyeballed and I've also seen a video where the guy said he levels his mill on each job. I'm inclined to think it should be leveled. Opinions?
LT 35 hydraulic portable "73"Ford 335 tractor - lots of chains
Online LeeB
Re: Leveling a LT 35
« Reply #1 on: August 12, 2019, 08:37:27 AM »
Doesn't have to be dead on level but does need to be evenly supported. Many actually let the mill lay a little lower on  side toward the log stops so the log will roll up against it. Normally I just eyeball it.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: August 12, 2019, 08:49:32 AM »
   I normally just eyeballed mine unless I had a level handy then I got it a little closer especially front to rear so the head doesn't want to roll forward of back on it's own or make the power drive work harder than it needs to. However last week I bought a pair of stick on RV levels and stuck them on the mill at 90 degree angles to use for both directions to help. They don't look to be super accurate but should be plenty close for what I need. I figure they were worth a $5.50 investment. I think Mr. Tom posted that idea in the modifications thread Bibbyman started a couple hundred years ago and I just happened to be passing the RV dealer and had some time and got around to doing it last week.
  I always take several small boards (2X8's and such) to put under the landing gears to get them more level and I take 3-4 3' long 1X6's to put under the wheel on the low side. I usually just drive up on them to get it mostly level side to side. I don't have FAOs on my mill so I also take along an old car bumper jack I sometimes use. It only takes a couple minutes for each job and seems well worth the time and effort. The jack is much easier to use to level those 2 inside landing gears which are such a pain to reach.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: August 12, 2019, 06:54:53 PM »
The mill doesn't have to be LEVEL, just SOLID and eyeball close is close enough!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline millwright
« Reply #4 on: August 12, 2019, 07:01:56 PM »
I used to eyeball level my 35, but after putting on faos I level it with a 2 level, it makes it a lot faster to set up.
Offline jmouton
  • never enough time
    • Log-Gistics
« Reply #5 on: August 12, 2019, 09:33:03 PM »
we use a 4 ft or 6 ft level and get it close as long as your making straight and flat lumber , the mill get s moved around alot when we are milling portable cuz we are usually in the dirt , so as long as the fao s  are snug not tight and wheels still on the ground
lt-40 wide ,fiat tractor,bobcat,international flatbed,10 ton trailer, stihl 075,041,029,066,and a 2015 f-350,and a oldwheel loader ,grapple system coming soon!!
Offline Arkyrick
« Reply #6 on: August 12, 2019, 09:36:04 PM »
Thanks everyone good advice😊
leveling or non leveling???
Started by bkellyvtme on Forestry and Logging
Last post March 03, 2009, 11:43:18 AM
by bkellyvtme
Log leveling
Started by redbeard on Sawmills and Milling
Last post September 17, 2011, 07:27:00 PM
by sigidi
leveling lt-15 sawhead
Started by mad dog on Sawmills and Milling
Last post May 21, 2009, 07:18:46 AM
by MartyParsons
leveling tracks
Started by rvrdivr on Sawmills and Milling
Last post November 08, 2004, 05:36:21 AM
by Buzz-sawyer
