Author Topic: Throttle handle won't engage  (Read 215 times)
Offline Arkyrick
  • Doing it since 2008
« on: August 12, 2019, 08:34:33 AM »
My throttle handle won't engage fully when I pull down on it. It has done this 3 times and after a couple of trys it works. This is a new mill  Hydraulic LT 35
LT 35 hydraulic portable "73"Ford 335 tractor - lots of chains
Offline LeeB
Re: Throttle handle won't engage
« Reply #1 on: August 12, 2019, 08:47:26 AM »
Wood-Mizer support is quite good. Give Will a call. He's pretty knowledgeable on the mills.
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: August 12, 2019, 08:58:41 AM »
   I am sure WM can help. I'd have first thought the wire link had slipped off but if that was the case it would never engage. I once couldn't get the tensioner arm to engage then I remembered to put a band back on and it worked fine then. ::)
Online Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: August 12, 2019, 06:51:28 PM »
Good one, WV!   ::)  ;D
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
MX 34 Norwood Throttle Handle
Started by catskillpond on Sawmills and Milling
Last post May 05, 2011, 06:45:59 PM
by catskillpond
governor throttle lever, pushing throttle instead of pulling
Started by SCSawyer on Sawmills and Milling
Last post July 31, 2016, 09:23:05 AM
by mburrow
Stihl 031 clutch won't engage
Started by captinjack on Chainsaws
Last post July 12, 2006, 05:49:52 PM
by Al_Smith
Hercules drive won't engage
Started by barbender on Forestry and Logging
Last post November 20, 2008, 10:20:12 AM
by barbender
