Author Topic: Edger  (Read 578 times)
Offline Bruno of NH
Edger
« on: August 13, 2019, 05:20:57 PM »
Can't get my new edger to cut true curves off
Any ideas
I haven't used it much because it makes me mad been edging on the mill
That's what I got the edger for.
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Offline 47sawdust
Re: Edger
« Reply #1 on: August 13, 2019, 06:47:06 PM »
In feed/out feed dead level?
Mick
Online moodnacreek
  • Sawin by the notches
Re: Edger
« Reply #2 on: August 13, 2019, 07:17:50 PM »
Not an unusual problem. What kind of feed , belts, rollers or chain?
Online moodnacreek
Re: Edger
« Reply #3 on: August 13, 2019, 07:20:40 PM »
Oh yeah, spread the saws out and see how a board goes through.
Offline Bruno of NH
Re: Edger
« Reply #4 on: August 13, 2019, 07:22:39 PM »
Dead level
Feed rollers with chain
Offline Southside
Re: Edger
« Reply #5 on: August 13, 2019, 09:27:29 PM »
Check the out feed fence against the fixed blade, make sure it is dead square and at the same distance from the frame as the corresponding face of the blade, if it's not then it is pushing the lumber to the side as it passes by.
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Edger
« Reply #6 on: August 14, 2019, 06:39:09 AM »
Did you not run it when you first got it?
A&P saw Mill LLC.
License NH softwood grader.
Offline Bruno of NH
Re: Edger
« Reply #7 on: August 14, 2019, 07:09:17 AM »
It's not cut right from the beginning I thought it might have something to do with the old mill
Offline Sixacresand
  • John and Nancy
Re: Edger
« Reply #8 on: August 14, 2019, 07:20:16 AM »
Hang in there.  You will figure it out.
Offline Bruno of NH
Re: Edger
« Reply #9 on: August 14, 2019, 07:24:51 AM »
Boards with a hook or varying width don't sell
Not what I was expecting
Online Oliver05262
Re: Edger
« Reply #10 on: August 14, 2019, 07:34:56 AM »
Bruno, have you asked Darren about the problem? He ought to be able to give you an idea of where to check for alignment of the rolls, the saw arbor and the guides. I suspect as Southside suggested that something is pushing against the board as it exits the edger. Good luck in figuring this out.
"You can't do wrong by doing good"
It's OK to cry.
Online moodnacreek
Re: Edger
« Reply #11 on: August 14, 2019, 08:15:27 AM »
Feed rolls must be parallel with arbor. Any thing on the out feed that drags on  one edge of the board will start a curve.  Also a piece of bark, pitch, etc. caught in a feed roll will do the same. Even an out feed dead roll that is not parallel or high on one side ditto. There are many things; a big knot, one saw very dull, boards too hard or too thick for the feed speed or power . If machine has a small dia. mandrel it will vibrate in tough cuts and shake the board and curve.  A guide light set on the fixed saw is a great help.
Offline Ron Wenrich
Re: Edger
« Reply #12 on: August 14, 2019, 05:44:00 PM »
Have you changed teeth in the edger blades yet?  I've found that you have to eliminate the problems of other people's saw maintenance practices first.  New teeth will tell you whether its in the saws or in the rolls.
Edger
Started by CX3 on Wanted
Last post December 21, 2015, 11:31:11 AM
by CX3
edger
Started by jmouton on Sawmills and Milling
Last post November 28, 2016, 08:14:09 PM
by paul case
Edger
Started by Ohio_Bill on Sawmills and Milling
Last post September 11, 2014, 09:59:52 PM
by redprospector
My new to me edger
Started by WoodenHead on Sawmills and Milling
Last post October 18, 2013, 06:50:44 AM
by Peter Drouin
