Author Topic: One 10HP motor, or 2-5hp motors  (Read 1046 times)
Offline nathandcasey
« on: September 05, 2019, 02:40:13 PM »
So, Iím planning on building my mill, and Iím noticing that it is significantly cheaper and lighter in weight to use 2-5hp motors instead of one 10HP motor. Is using 2 motors with one helping the other using a double pulley actually the same as using one-ten hp motor? Iíve been in the motor-deciding phase for a long time because I canít make up my mind! Help me! Thank you!
Online Crusarius
  • Lost in....
    • RockModified.com
Re: One 10HP motor, or 2-5hp motors
« Reply #1 on: September 05, 2019, 03:07:39 PM »
Interested to know the outcome on this. I do know that with cars when you add a second engine they get quite a bit faster. I would think with sawmills it would be the same deal. I dunno if it will equal 10hp though.
Offline muggs
    • Hardins industries
« Reply #2 on: September 05, 2019, 03:45:22 PM »
two 5s should equal one 10. Motors is what I do. But remember you now have to buy two motor starters.
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #3 on: September 05, 2019, 04:10:09 PM »
I would think 1 motor starter to start one motor and the motor to start the other motor. Have one start before the other.
Offline Den-Den
    • Dennis Wood Art
« Reply #4 on: September 05, 2019, 05:08:10 PM »
I have some doubts that you are comparing equal quality motors.  Rigging two motors on one load is possible but there are several opportunities for things to go wrong.  Hard to imagine that total cost would be lower unless you already have the motors.
« Reply #5 on: September 05, 2019, 06:32:51 PM »
Okay, so I was at work when I typed this and forgot one critical detail. The motors Iím referring to are electric motors. Now letís see where the conversation goes. 😅
Offline TreeStandHunter
  • ISA Arborist from Michigan
« Reply #6 on: September 05, 2019, 07:08:12 PM »
I think it is clear off the go that you are talking electric. I canít imagine that you will be happy with that setup, if it were ideal there would be mills manufactured that way. The ease of having 1 motor and it costing slightly more too run than 2 smaller motors (the amp draw canít be that much more) will be worth the hassle of figuring out how to design 2 motors into a system that will be easy to maintain.
In the process of building my own mill.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #7 on: September 05, 2019, 07:41:27 PM »
Twice the motors, twice the electrical wiring/devices, twice the mechanics to make them work together = many more ways for Murphy's Law to be applied.
In other words, keeping it simple with one motor reduces the number of moving parts, electrical connections and reduces the things to adjust, wear and/or break.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline sawguy21
« Reply #8 on: September 05, 2019, 08:26:19 PM »
X2 I can't see it working unless both motors are perfectly synchronized which is unlikely.
Offline Southside
« Reply #9 on: September 05, 2019, 08:44:59 PM »
Any slight deviation in RPM or belt tension will result in a reduced net gain.  Now if you could put two motors via a transmission system and clutch into your input shaft then perhaps you would see the gain, but then you would have a parasitic loss to overcome, so in the end even if it works in theory I don't see it working in practice.
Offline Don P
    • Calculator Index
« Reply #10 on: September 05, 2019, 08:50:07 PM »
I saw a circle mill one time running 2 20hp three phase motors, it worked well and one thing that seemed like a good idea was he had set them up to pull on the mandrel in opposite directions, balancing the side load on the mandrel bearings. There is a substantial difference in price as single phase motors go over 5 hp but check on the built cost difference. Locked to the hertz on the grid I believe they are synchronous.
10hp 3 phase motors are cheaper, it might be worth exploring building a rotary phase converter out of one to drive the other. Edit Duh-huh, the rotophase would need a 20 to drive the 10. But once it is spinning it can drive another motor, (blower, edger)
Offline donbj
« Reply #11 on: September 05, 2019, 09:04:13 PM »
It can be done but is it worth it money wise and mechanically. Back in my working days I worked on a large dragline that had four 1250hp,yes 1250hp, electric motors on the drag, and four 1250hp motors on the hoist. They were paired two to a gearcase with one gearcase driving the front of the drag drum and the other case driving at the rear of the drag drum. Same for the hoist.
The propel system was two 500hp motors on each side of the house connected to the propel gearcases that drove the large eccentrics for the walking shoes.
Anyway, a little off topic but if it can be done large scale it can be done small.
Woodmizer LT40HDG24
Offline Hobby_Saw
« Reply #12 on: September 05, 2019, 10:10:10 PM »
I've had this same discussion over the last year or so, to decide if I should replace the gas engine on my homemade mill. The disclaimers-- I am not an engineer but I talked to one , along with a couple of top notch industrial electrical contractors and we came up with this.
The complexity has already been addressed. Two starters would be best but once one is started the other could probably be switched on once up to speed (we never actually tried). Our plan was to have one motor drive a single V belt to one groove of a 3 groove pulley on the other motor and drive the blade with the other 2 grooves. One motor will always be a little stronger/ more efficient and so drive with most of the power but the other will increase its load share as the stronger slows due to load then they should team up as needed.  So-- one will carry most of the load until the other can "catch" up. We planned on using 2 amp meters to monitor the load sharing of the motors.
I rebuilt the gas engine and regained it's former power and so we never got past the theory stage but it was a fun, thoughtful exercise!
Offline Woodpecker52
« Reply #13 on: September 05, 2019, 10:36:38 PM »
You will find the more horsepower the better!! At a minimum 14hp.  On hardwood my 14 is ok but would be nice to have 22-24.  but for a hobby 14 is ok.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline Don P
    • Calculator Index
« Reply #14 on: September 05, 2019, 10:51:07 PM »
10HP electric is about the same as 25 HP gas, and rock steady rpms.
Offline ladylake
« Reply #15 on: September 06, 2019, 06:10:08 AM »
  Do you have 3 phase, if not 2 single phase motors is a good idea to get some extra power without having to use a phase converter. I think 3 phase motors can be bought cheap but you need a good phase converter.  Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline luap
  • Not as good as I once was
« Reply #16 on: September 06, 2019, 12:23:19 PM »
It can be done. I helped a friend do this on a fanning mill. I only did the mechanical work of mounting the motors, boring sheaves, keyway etc. He did the electrical after consulting an electrician. The smaller motors were available for less cost than the single. He was very happy with the results. also as mentioned the starters were less also. He already had a collection of sheaves, so no cost there.
Offline longtime lurker
« Reply #17 on: September 07, 2019, 05:18:14 PM »
The main advantage of using two smaller motors vs a single larger one is at starting. Being able to sequentially start smaller motors requires a lot less current draw. Think of it like hand cranking a motor - it takes a lot less effort to crank two 4 cylinders geared to the same shaft than it does to crank a single 8 cylinder for the same output.
Other than that its a PITA way to setup.
Look at your electrical situation and if you can swing the 10HP comfortably go that way. And I say comfortably because if you have just barely enough starting current you'll be forever replacing soft starts. A good VFD is also an option that will better handle marginal starting currents. They (VFD's) are expensive only once.
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #18 on: September 07, 2019, 09:19:24 PM »
I am usually against electric clutches, but with this setup I think that be the way to go. Keep the motor running just disengage the clutch to stop the band.
« Reply #19 on: September 20, 2019, 11:23:58 AM »
Thanks everyone for all of your help. After searching around, I got a brand new 3-phase, 10hp Baldor motor for $250 and a 42a, 25hp rated VFD for 180. After looking around so much, I think I'll be more than happy with this setup.
Woodmizer LT10 belt tension with new 10hp motor
Started by ntkonn on Sawmills and Milling
Last post November 23, 2014, 08:43:22 PM
by ntkonn
10hp deisel vs 15hp gas
Started by Bruno of NH on Sawmills and Milling
Last post April 16, 2019, 07:15:50 PM
by richhiway
opinions on 10hp electric
Started by brdmkr on Sawmills and Milling
Last post June 09, 2011, 11:13:48 PM
by jim blodgett
10hp electric or 20hp gas?
Started by hackberry jake on Sawmills and Milling
Last post December 22, 2014, 08:59:08 AM
by hackberry jake
