Author Topic: Cummins V378C V-6 Diesel Coolant Filter Clark Skidder HELP PLEASE  (Read 384 times)
Offline Natureswaytreef
« on: September 07, 2019, 11:46:37 PM »
Guy I need help, I'm restoring this 1973 Clark Skidder 666C and back in the day my Uncle removed the hoses to the coolant filter, Can anybody help me. I know as seen in the pic one hose comes into the filter from the valve at the water pump housing, Where does the other hose go that comes out of the filter, PLEASE HELP IM STUMPED.
Offline barbender
Re: Cummins V378C V-6 Diesel Coolant Filter Clark Skidder HELP PLEASE
« Reply #1 on: September 07, 2019, 11:52:51 PM »
I can't help, other than to say that if that engine is related to the 855 (I think that's the model, big V8) you want that filter operable and use a coolant conditioner. They were notorious for pitting liners. Sounds like a cool machine, btw!
« Reply #2 on: September 07, 2019, 11:58:42 PM »
Thanks for the reply, I need to get this hooked up, If you know of anybody that could help that would be great. I called Cummins and they couldn't find any diagrams showing how it is to go.
Thanks again.
« Reply #3 on: September 08, 2019, 12:27:14 AM »
Here's
 a pic I found from a listing, See the hose coming out of the valve on the left then up to the filter, its the same as mine, I just need to know where the hose on the right plumbs in to.
Offline snowstorm
« Reply #4 on: September 08, 2019, 07:46:49 AM »
back to the radiator or over flow bottle.
« Reply #5 on: September 08, 2019, 10:46:01 AM »
Thanks for the reply, Ill see if I can find a inlet on the overflow can, I see on the pic that it shows 2 on the side of the large overflow can, I don't think mine has 2 but only 1.
Thanks again.
« Reply #6 on: September 09, 2019, 11:50:29 PM »
Im also looking for a left side exhaust manifold.
Offline snowstorm
« Reply #7 on: September 11, 2019, 07:11:43 AM »
dont run the coolant filter to the over flow bottle. any where else would work
« Reply #8 on: September 15, 2019, 04:41:31 PM »
I talked to Cummins they said to run it to the tank on top, Just splice into the feed that goes to that tank from the water pump., Here is the pic that Cummins support sent me. They circled in red.
Problem with cummins 350 (coolant in fuel)
Started by Grunex on Forestry and Logging
Last post May 19, 2013, 11:13:05 PM
by kiko
Clark 666C Coolant Leak?
Started by coxy74 on Forestry and Logging
Last post April 17, 2014, 10:17:54 PM
by treeslayer2003
Diesel coolant
Started by CCCLLC on Forestry and Logging
Last post September 02, 2018, 09:08:01 PM
by Oliver05262
Clark 664 transmission filter
Started by BurkettvilleBob on Forestry and Logging
Last post November 19, 2018, 09:22:11 AM
by mike_belben
