Author Topic: Drying in my solar kiln  (Read 315 times)
Offline briand7878
« on: September 14, 2019, 03:25:50 PM »
I recently built a solar kiln and placed a bunch of walnut and red oak in it. As the time goes by I notice that the humidity in the kiln gets less and less which Is how it works I believe. Right now itís 138 inside with 15% humidity. I leave the vent open a little bit as directed but Iím not sure if itís getting too dry. Do I need to do anything to tame this beast? I havenít been inside to test the lumber, but there is no chance itís totally dry already.
Offline scsmith42
    • Whispering Pines Farm
Re: Drying in my solar kiln
« Reply #1 on: September 14, 2019, 04:57:14 PM »
How long has the lumber been in the kiln?
When was the lumber milled?
How thick is the lumber?
How accurate is your RH% measuring device?
Tom's 3638D Baker band mill
Offline briand7878
« Reply #2 on: September 14, 2019, 06:14:10 PM »
Since August 22nd
August 21st
1Ē quarter sawn red oak.
I have no idea, itís an accurite thermometer but seems to be working well.
Offline scsmith42
« Reply #3 on: September 17, 2019, 04:42:31 PM »
In a nyle kiln I typically run 4/4 QSRO for 5-6 weeks (about a week longer than FSRO).
In a solar kiln it is usually twice that time, due to the fact that itís only operating 12 hours a day or so.  Usually I leave my vents totally closed when drying QSRO in a SK and allow the small amount of leakage to exchange the air.
So from a QSRO standpoint, your drying rate seems very fast.
IF it were me, I think that I would close the vents totally and allow the RH% to increase inside the kiln for several days, so that the surface MC% will not be too low.
Iíd also check several boards with a pin type moisture meter - driving the pins in 1Ē from the edge of the boards.
Mental Exercise! Hybrid kiln design (solar drying concept w/o solar heat)
Started by scsmith42 on Drying and Processing
Last post March 31, 2016, 10:51:46 PM
by GeneWengert-WoodDoc
New solar kiln with drying question
Started by briand7878 on Drying and Processing
Last post August 26, 2019, 04:57:07 PM
by briand7878
Solar Kiln - Winter Drying
Started by Woodslabs on Drying and Processing
Last post September 22, 2015, 08:36:37 AM
Drying different species in a solar kiln
Started by Peakebrook on Drying and Processing
Last post July 25, 2009, 06:36:54 PM
by Peakebrook
