Author Topic: LT40 Simple Set Question  (Read 265 times)
Offline Poquo
« on: September 15, 2019, 09:12:29 AM »
I noticed when using simple set the head would go down a little bit past the set point then up to right place , is this normal ?
Offline Bruno of NH
Re: LT40 Simple Set Question
« Reply #1 on: September 15, 2019, 10:01:51 AM »
Yes
I have a new mill and that's how mine works
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Offline Poquo
« Reply #2 on: September 15, 2019, 10:17:02 AM »
Thanks Bruno mine is used with 400 hours .
Offline Percy
  • Resident trouble maker
« Reply #3 on: September 15, 2019, 10:43:51 AM »
My accuset 2 does the same thing..coming "up" to the target mark is more accurate Im told, than coming "down" to the mark. Like tuning a guitar string... ;D
Offline Bandmill Bandit
« Reply #4 on: September 15, 2019, 10:44:19 AM »
The reason for the "bump up" is to ensure the lift chain ABOVE the head is as tight as possible. You need to do the same when you do a manual set as well. Otherwise the head will drop slightly when you engage the clutch to start your cut.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
Offline Poquo
« Reply #5 on: September 15, 2019, 05:51:26 PM »
Thanks for all the help , just wanted to make sure I didn't need to adjust it .
LT40 Simple Set
Started by ncsawyer on Sawmills and Milling
Last post March 24, 2016, 05:27:14 PM
by Solomon
Simple question.
Started by hackberry jake on Sawmills and Milling
Last post March 11, 2012, 03:21:18 PM
by jim blodgett
Simple Question
Started by grassfed on Forestry and Logging
Last post April 07, 2011, 07:47:46 PM
by Ron Scott
Simple heartwood question
Started by Mortice on Timber Framing/Log construction
Last post March 06, 2008, 07:36:54 PM
by ohsoloco
