Author Topic: Planing 22" wide slabs  (Read 910 times)
Offline Southside
Re: Planing 22" wide slabs
« Reply #20 on: September 22, 2019, 09:41:46 AM »
I do have a stack of 2", air dried walnut slabs that need to go through the kiln at some point here in the next month-ish.
Online doc henderson
« Reply #21 on: September 22, 2019, 10:10:00 AM »
@GeneWengert-WoodDoc has recommended an attic space, but do not know if you can get them in.  I am in Ks and occ check.  my oak table is at 7.2%.  ac all summer long.  I would check wood items in you home and make that your target.  If it will remain sort of rustic, then a little movement may not be as obvious.  will these be solitary objects or have joints.  my outside elm 2" live edge is 8.6% just under a tarp.  of course we have different locals and conditions.  Is 15% as low as you can go in your part of NY.  I lived in Albany for 4 years.  My ac was out for 2 months this summer in my shop and finally the new ac has caught up with all the humidity that soaked back into all the dry wood I have in there.  I have been dumping a 5 gallon bucket of water a day for a month.  it is down to 45% in there @ 70.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #22 on: September 22, 2019, 07:52:26 PM »
well these slabs are definitely not perfect. there are defects that will be included in the final product. The biggest problem is the 3 sided scribe. So I am slightly concerned with it shrinking more and pulling off the walls. But if that happens a backsplash is not the end of the world. Do keep wondering if I will need to epoxy them just to fill the spots around the knots.
the attic is not a bad idea. I should try to get those up there this week. Only problem is the attic is in the shop so its not heated or conditioned. I do think we have a few more weeks of hot at least.
« Reply #23 on: September 22, 2019, 08:06:32 PM »
I think Dr. Wengert has stated that if it is 15 warmer than ambient it will help.  or cover in plastic or just put it in your house. but it is bigger than flooring that can acclimate in a few weeks.  yes if it shrinks, and it will some,at least a quarter round
Looking for help - planing wide slabs
Started by Engineer on General Woodworking
Last post October 27, 2017, 06:47:07 PM
by scsmith42
25" wide curly spalted maple slabs
Started by Daren on Sawmills and Milling
Last post August 17, 2005, 08:41:41 PM
by chet
moved
MOVED: Wanted: Crotch Slabs & Wide Slabs with natural edge
Started by Tom on Sawmills and Milling
Last post February 12, 2006, 01:02:35 PM
by Tom
Planing slabs
Started by D6c on Sawmills and Milling
Last post September 26, 2018, 11:19:48 AM
by OffGrid973
