Author Topic: solar pump for pond  (Read 155 times)
Offline Qweaver
  • The cabin is done and we love it
solar pump for pond
« on: September 16, 2019, 11:20:41 AM »
I built my pond on a low flow spring. Natural flow and rain don't keep up in dry periods.  I'd like to add solar water pumping from the adjacent river.  I'd have to lift the water 12'. Anyone done this?  Is there a good kit available?
Offline Southside
Re: solar pump for pond
« Reply #1 on: September 16, 2019, 11:44:39 AM »
Is there enough current to run a ram pump instead?
Offline Qweaver
« Reply #2 on: September 16, 2019, 12:49:12 PM »
No, very slow flow.  I'm currently using a Honda 1022 generator driving a shallow well pump.  Works well...just too costly.
Offline nativewolf
« Reply #3 on: September 16, 2019, 12:58:24 PM »
Should be no problem there are hundreds of similar setups sold in the west every year, they pull deepwater wells on solar setups to water sheep and cattle ponds/tanks.  Small ones can do 500 gallons a day larger ones much more.
https://thesolarstore.com/dankoff-solar-slow-pumps-c-53_63_184_191.html
Just one of many options and I just pulled that one to give you a starting point on your own exploration.  The good news is it is a common project.  Good luck!
Liking Walnut
Solar Pond Aeration Anyone?
Started by Jason_AliceMae Farms on General Board
Last post July 30, 2016, 05:53:33 PM
by John Mc
Recommendations for solar powered well pump system
Started by dhutch on Alternative methods and solutions
Last post August 22, 2011, 08:46:31 AM
by LOGDOG
Diesel Primary pump from tank to injector pump
Started by Ironwood on General Board
Last post January 25, 2005, 08:12:11 PM
by Ironwood
Aluminum can solar heater or thermal mass storage? Solar klin
Started by Doug_D on Drying and Processing
Last post May 12, 2010, 10:06:57 AM
by Den Socling
