Author Topic: Hyd hose life  (Read 410 times)
Offline ladylake
Hyd hose life
« on: September 20, 2019, 04:07:01 PM »
  Some last rather well, I just replaced one of the last original hoses on my B20, 17 years and almost 15000 hours isn't bad.  Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline moodnacreek
  • Sawin by the notches
Re: Hyd hose life
« Reply #1 on: September 20, 2019, 06:37:20 PM »
Rubbing and sun light or flexing at the end is the ruin of hydrolic hoses.
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Hyd hose life
« Reply #2 on: September 20, 2019, 06:53:03 PM »
   Rough slab pieces falling off the bucket on my little FEL and breaking the fittings is usually the cause for replacement on mine. I do have one that is wearing on it that probably should be replaced soon as the wire under the rubber coating is showing.
Offline sawguy21
Re: Hyd hose life
« Reply #3 on: September 20, 2019, 08:14:25 PM »
Steve, I would say you got your money out of that one. I watched my buddy shorten and reconnect a power steering hose on a 20 year old logging truck, I have no idea how old the hose is. I would have replaced it but that's just me, he is cheap.
Offline Larry
Re: Hyd hose life
« Reply #4 on: September 20, 2019, 09:15:56 PM »
I built my log splitter 31 years ago.  Sits in the same spot outside without cover.  Original hoses, but the rubber is completely gone.  All I can see is the steel braid.
Offline longtime lurker
Re: Hyd hose life
« Reply #5 on: September 20, 2019, 11:24:22 PM »
Around here once you see the wire exposed you've got about a year to go. Salt in the air from the ocean breeze, and rain rain rain.
I try not to run them to fail myself... cheaper to replace a hose than a hose + a heap of oil, and its the difference between scheduled maintenance and a breakdown at an always inconvenient time
hydraulic hose
Started by bedway on General Board
Last post September 25, 2011, 12:20:07 PM
by maple flats
Radiator hose
Started by loggerman1959 on Forestry and Logging
Last post October 29, 2019, 10:16:05 PM
by Al_Smith
ANyone know what this hose is or if I am in bad shape??
Started by Kipper on Sawmills and Milling
Last post December 01, 2014, 09:00:21 PM
by MartyParsons
Handlebar hose
Started by ramv102000 on Chainsaws
Last post December 07, 2013, 11:25:30 PM
by sharkey
