Author Topic: Oops!  (Read 1862 times)
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Oops!
« Reply #40 on: November 01, 2019, 08:21:19 AM »
I will say this; if that truck door stays open, the inside will get sawdust.  :o   Same as if a window in left open.  :-X
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
Re: Oops!
« Reply #41 on: November 01, 2019, 08:32:10 AM »
I have doen it where it took a few hours to hand lift it back up at a customers,, no heavy equipment to lift it with. The last thing I do after I saw the last board is lift the back stops, move the clamp all the way out, then I shut down the mill aand move lumber and load a log on th arms.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
Re: Oops!
« Reply #42 on: November 01, 2019, 01:28:05 PM »
That is the reason that if you have an energy chain (gooseneck) with your hydraulic lines in it... you always bring the mill back before you roll a log or cant.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline SawyerTed
  • Summey Lumber Services, LLC
Re: Oops!
« Reply #43 on: November 01, 2019, 07:32:43 PM »
My wife's cousin had me come to the home place of their grandparents to saw some 32" red oak logs.  Yep, rolled one over the back stops and off the mill.  No equipment to get the log back in place so I had to break the mill down and turn it around to get the log.  I was sawing the lumber for family (aka free of charge) so the time didn't matter.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline Stephen1
    • muskoka Sawmill
Re: Oops!
« Reply #44 on: November 02, 2019, 08:33:07 AM »
On the WM they get stuck between the frame and the tire, not a good spot as you have to lift them out
Offline samandothers
Re: Oops!
« Reply #45 on: November 02, 2019, 10:07:30 AM »
I just did this yesterday demonstrating the log loading process to my step son. No pics but I got to cross that off the list
I am sure you immediately shared this is to show what not to do and is part of the demonstration.
oops
Started by james on General Board
Last post December 21, 2004, 05:04:58 PM
by J_T
1 Oops=new bar!
Started by Caloren on Chainsaws
Last post October 21, 2014, 08:48:00 PM
by Wild Man Jack
OOPS
Started by Wildflower on The Outdoor Board
Last post October 29, 2006, 05:30:07 PM
by Jeff
oops...oil in the gas res, gas in the oil res
Started by michaelvp on Chainsaws
Last post August 06, 2008, 10:58:17 AM
by joe_indi
