Tally-I/O
Author Topic: Radiator hose  (Read 490 times)
Offline loggerman1959
Radiator hose
« on: October 28, 2019, 02:56:05 PM »
I have a 1978 international S8A skidder , which has developed a hole in the lower radiator hose . It's a 3 inch diameter off set hose , which I have looked everywhere for with no luck . Any of you folks have any idea where I could look for one ? Its beginning to get frustrating,  as no one seems to carry anything like that .
Offline sealark37
Re: Radiator hose
« Reply #1 on: October 28, 2019, 03:12:16 PM »
There is a guy over in Plattsburgh that deals in military trucks and forestry equipment.  He may be able to match a hose that will work.  You probably need to take the old hose with you when you search.
Re: Radiator hose
« Reply #2 on: October 28, 2019, 03:35:35 PM »
Any name available ??
Offline mike_belben
  • Pulp Friction
Re: Radiator hose
« Reply #3 on: October 28, 2019, 06:06:43 PM »
Build a metal offset from sched 40 or copper plumbing, connect the ends with rubber straights and never deal with this obsolete part issue again.
Revelation 3:20
Re: Radiator hose
« Reply #4 on: October 28, 2019, 07:15:44 PM »
Will schedule 40 work on a cooling system mike ?
Offline mike_belben
  • Pulp Friction
Re: Radiator hose
« Reply #5 on: October 28, 2019, 09:49:25 PM »
Has been in steam heated factories for a few centuries now so id reckon so.
Revelation 3:20
Offline Southside
Re: Radiator hose
« Reply #6 on: October 28, 2019, 09:52:54 PM »
Mike - would aluminum exhaust tubing work?  Could have a shop bend it to what he needs right up to the connection.
Offline donbj
Re: Radiator hose
« Reply #7 on: October 28, 2019, 11:56:06 PM »
I would think even 3" muffler pipe would work. Could get it bent or welded how you want. Cooling systems only generate 15-20 psi anyway. As mentioned, connect with some straight rad hose.
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065
Offline thecfarm
Re: Radiator hose
« Reply #8 on: October 29, 2019, 07:25:23 AM »
I replumbed a '76 Ford radiator. :D  Used 2 or 3 inch copper. Pricey. Sch 40 would of been cheaper,but was not on the FF than. ;D The inlet and outlet was on the wrong side.
Re: Radiator hose
« Reply #9 on: October 29, 2019, 08:43:08 AM »
Thanks for the input fellas , I'll get some schedule 40 and get to work
Offline mike_belben
  • Pulp Friction
Re: Radiator hose
« Reply #10 on: October 29, 2019, 02:09:07 PM »
Any metal tubing would work.  Hi temp pvc will also but i cant say about the glue.  My friend used pvc for his 125 psi shop air compressor but its not at elevated temp so the only reason i didnt suggest.
Use whatever is cheap that'll make a good hose connection.  Sch 40 and 80 are thick enough to chuck stubs in a lathe and turn hose barbs or nipple ends into them for clamp integrity.  Its worked for the water pipes on the water to air intercooler i fabbed for my IH for like 40k miles with no issue.
Revelation 3:20
Offline thecfarm
Re: Radiator hose
« Reply #11 on: October 29, 2019, 04:21:20 PM »
My plumbing job held on that copper pipe,never cut any grooves in that. Just run the rad hose over it and clamped it. That held for years.
Offline Al_Smith
Re: Radiator hose
« Reply #12 on: October 29, 2019, 05:02:03 PM »
FWIW the top radiator tubing for a John-Deere model A  is nothing but steel tubing about as thick as electrical thin wall conduit .It might rust out in 60 -70 years .
Offline bushmechanic
  • Someone else has it worse than you.
Re: Radiator hose
« Reply #13 on: October 29, 2019, 09:13:16 PM »
 Here's one I fabed up because I couldn't find what I needed!
Offline Al_Smith
Re: Radiator hose
« Reply #14 on: October 29, 2019, 10:16:05 PM »
I looked at flea bay .It has some 3" stuff with some creativity might work.
need help oil in the radiator
Started by nyyounggun16 on Forestry and Logging
Last post March 03, 2015, 07:56:10 AM
by scsmith42
Radiator ?
Started by Autocar on General Board
Last post January 15, 2012, 09:42:09 AM
by Magicman
Radiator plugged
Started by redneck on Forestry and Logging
Last post May 23, 2011, 07:45:52 AM
by Burlkraft
Radiator Filter?
Started by Magicman on Sawmills and Milling
Last post September 25, 2009, 04:20:12 PM
by backwoods sawyer
