Tally-I/O
Author Topic: Radiator hose  (Read 491 times)
Offline loggerman1959
Radiator hose
« on: October 28, 2019, 02:56:05 PM »
I have a 1978 international S8A skidder , which has developed a hole in the lower radiator hose . It's a 3 inch diameter off set hose , which I have looked everywhere for with no luck . Any of you folks have any idea where I could look for one ? Its beginning to get frustrating,  as no one seems to carry anything like that .
Offline sealark37
Re: Radiator hose
« Reply #1 on: October 28, 2019, 03:12:16 PM »
There is a guy over in Plattsburgh that deals in military trucks and forestry equipment.  He may be able to match a hose that will work.  You probably need to take the old hose with you when you search.
Re: Radiator hose
« Reply #2 on: October 28, 2019, 03:35:35 PM »
Any name available ??
Offline mike_belben
  • Pulp Friction
Re: Radiator hose
« Reply #3 on: October 28, 2019, 06:06:43 PM »
Build a metal offset from sched 40 or copper plumbing, connect the ends with rubber straights and never deal with this obsolete part issue again.
Revelation 3:20
Re: Radiator hose
« Reply #4 on: October 28, 2019, 07:15:44 PM »
Will schedule 40 work on a cooling system mike ?
Offline mike_belben
  • Pulp Friction
Re: Radiator hose
« Reply #5 on: October 28, 2019, 09:49:25 PM »
Has been in steam heated factories for a few centuries now so id reckon so.
Revelation 3:20
Offline Southside
Re: Radiator hose
« Reply #6 on: October 28, 2019, 09:52:54 PM »
Mike - would aluminum exhaust tubing work?  Could have a shop bend it to what he needs right up to the connection.
Offline donbj
Re: Radiator hose
« Reply #7 on: October 28, 2019, 11:56:06 PM »
I would think even 3" muffler pipe would work. Could get it bent or welded how you want. Cooling systems only generate 15-20 psi anyway. As mentioned, connect with some straight rad hose.
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065
Offline thecfarm
Re: Radiator hose
« Reply #8 on: October 29, 2019, 07:25:23 AM »
I replumbed a '76 Ford radiator. :D  Used 2 or 3 inch copper. Pricey. Sch 40 would of been cheaper,but was not on the FF than. ;D The inlet and outlet was on the wrong side.
Re: Radiator hose
« Reply #9 on: October 29, 2019, 08:43:08 AM »
Thanks for the input fellas , I'll get some schedule 40 and get to work
Offline mike_belben
  • Pulp Friction
Re: Radiator hose
« Reply #10 on: October 29, 2019, 02:09:07 PM »
Any metal tubing would work.  Hi temp pvc will also but i cant say about the glue.  My friend used pvc for his 125 psi shop air compressor but its not at elevated temp so the only reason i didnt suggest.
Use whatever is cheap that'll make a good hose connection.  Sch 40 and 80 are thick enough to chuck stubs in a lathe and turn hose barbs or nipple ends into them for clamp integrity.  Its worked for the water pipes on the water to air intercooler i fabbed for my IH for like 40k miles with no issue.
Revelation 3:20
Offline thecfarm
Re: Radiator hose
« Reply #11 on: October 29, 2019, 04:21:20 PM »
My plumbing job held on that copper pipe,never cut any grooves in that. Just run the rad hose over it and clamped it. That held for years.
Offline Al_Smith
Re: Radiator hose
« Reply #12 on: October 29, 2019, 05:02:03 PM »
FWIW the top radiator tubing for a John-Deere model A  is nothing but steel tubing about as thick as electrical thin wall conduit .It might rust out in 60 -70 years .
Offline bushmechanic
  • Someone else has it worse than you.
Re: Radiator hose
« Reply #13 on: October 29, 2019, 09:13:16 PM »
 Here's one I fabed up because I couldn't find what I needed!
Offline Al_Smith
Re: Radiator hose
« Reply #14 on: October 29, 2019, 10:16:05 PM »
I looked at flea bay .It has some 3" stuff with some creativity might work.
Radiator ?
Started by Autocar on General Board
Last post January 15, 2012, 09:42:09 AM
by Magicman
need help oil in the radiator
Started by nyyounggun16 on Forestry and Logging
Last post March 03, 2015, 07:56:10 AM
by scsmith42
Flushing Radiator - how often?
Started by Left Coast Chris on General Board
Last post March 09, 2014, 11:43:52 PM
by Left Coast Chris
black oil in radiator
Started by treefarmer87 on Forestry and Logging
Last post February 23, 2013, 12:36:35 PM
by treefarmer87
