Author Topic: LT40 hydraulics not working  (Read 732 times)
Offline brooksmill
  • retired!
« on: October 31, 2019, 01:03:23 PM »
Because of medical reasons mill has not been run in 2 yrs. Trying to get back into sawing and running into problems. Battery dead-replaced. Now hydraulics not working. Cleaned contact strip, tapped on solenoid-still nothing. Manual says to check fuse but cannot find fuse. Any ideas   Thanks
Online terrifictimbersllc
    • Terrific Timbers LLC
Re: LT40 hydraulics not working
« Reply #1 on: October 31, 2019, 01:31:27 PM »
There are things to check. This is what I would do first.
Take the cover off of the small box to the right of the battery.  Inside is a zig-zag looking fuse mounted between two studs.  One of them is attached to the battery and should read 12 V.  The other side should too, unless the fuse is blown. There should be a replacement fuse attached to inside of the cover of that box you took off. That other side of the fuse goes to one of the large studs on the solenoid which is in the box. Both should read 12V at all times if the battery is good, connected, and the fuse not blown.  If you have that 12V on one side of that solenoid inside the fuse box, and it still doesnt work, check back with us.
You can call WoodMizer Indianapolis and get tech support, electrical, and they will walk you through this.  Have a volt meter or continuity tester ready and the cover off the fuse box when you call.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: October 31, 2019, 01:35:02 PM »
   Calling WM will almost certainly fix the problem. I don't know where the fuses/breakers are on the LT40. Mine has 2 white button type breakers on the control panel so if I run the head up too high or other overload, boo boo, it trips and so far I have only had to push them back in and resume sawing. Good luck.
Offline jovol
« Reply #3 on: October 31, 2019, 01:38:45 PM »
Those circuit breakers are for things controlled on the control panel. If hydraulics aren't getting powered, it'd be the fuse in the fuse box next to the battery, the contact strip, or the hydraulic solenoid in the hydraulic box.
2017 LT50 wide, 2004 LT40 G28 (for sale), ms250, ms661 42 granberg, Logrite fetching arch, 2000 New Holland LS180, Ford 6.0s
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: October 31, 2019, 03:36:25 PM »
Be careful in that fuse box, there are lots of sparks in there waiting to get turned loose!
Once you do the power check, if you do anything else in there, disconnect the battery!
Your "no power to the hydraulics" problem could also be the little microswitch in the hydraulics box!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline John S
« Reply #5 on: October 31, 2019, 03:50:57 PM »
Did you check to see if the spring loaded contact is making good "contact" with the strip?
2018 LT40HDG38 Wide
Offline brooksmill
  • retired!
« Reply #6 on: October 31, 2019, 04:09:37 PM »
where is the spring loaded contact at?
Offline Bandmill Bandit
« Reply #7 on: October 31, 2019, 04:23:03 PM »
Its the piece that slides along the contact  strip mounted on the bottom front post of the saw head. It is attached to the mill with 2 bolts through a black bracket and has a short piece of heavy cable attached to it. if you need a picture I can go take one for you.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
« Reply #8 on: October 31, 2019, 04:24:33 PM »
  It is the piece that runs along the power strip. Follow the cord. Mine is a white plastic block about 3-4 inches long. You can wiggle it while toggling the hydraulics lever and if the hydraulics works there is a good chance this is not making good contact. BTW - did you check the troubleshooting section in you operator's manual?
« Reply #9 on: October 31, 2019, 04:32:53 PM »
At the other end of the heavy black wire coming off the solenoid in the fuse box.
Offline brooksmill
  • retired!
« Reply #10 on: October 31, 2019, 05:26:34 PM »
Please bandit if you can take picture would be great and how to adjust.  thks
« Reply #11 on: October 31, 2019, 06:09:45 PM »
   Off the cuff but as I remember you just use a hex wrench to tighten or loosen the two bolts in the block. Loosening them make the block extend out further pushing it tighter against the power strip. There is a spring under the bolt pushing against the block. Warning - if you have power on while doing this and cross the wrench against nearby metal you will weld the bolt head (Don't ask me how I know this  :D).
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #12 on: October 31, 2019, 06:51:21 PM »
I would not even think of diagnosing an electrical problem without a voltmeter/test lamp.  This is a very short length circuit.  Start at the battery and work outward from there.  Battery, solenoid, fuse, spring loaded contact, contact strip, hydraulic solenoid, and then the hydraulic pump.  As Chuck White mentioned above, the micro switch supplies 12 volts which energizes the hydraulic solenoid.
« Reply #13 on: October 31, 2019, 06:52:29 PM »
MM lists all the places to look for issues and he is 100% correct.
I think you have a ground issue based on personal experience. Once you have gon through the procedure I outline below and you still have no power we will look at other possibilities. 98% likely this process wil solve your issues IF you follow ALL the steps. if you need to talk to me let me know I can send you my Cell number.
I dont know how to add arrows but you can see that the bracket has slots under the 3/8 carriage head bolts to allow for adjustment.
DISCONNECT the battery FIRST!!!!!!!!
You will need a 9/16ths socket/ratchet or a 9/16 wrench , a small prying tool, 120 emry cloth or sandpaper and a SMALL hammer. Possibly a 7/16 socket and or wrench as well.
Bring the saw head just up to the copper strip so that you can move the head forward and back a few inches during the following process
Remove the 2 X 9/16ths carriage bolts and lift the bracket away from the mount plate inspect to ensure that the brass contact slide is in deed sliding on the center of copper strip and NOT catching the top or bottom edge of the plastic insulator strip.
Use the emry cloth/sand paper to polish the brass block and spray generously  with De-ox-it.
Remove the ground block and do the same to it.( more often than not the ground block is likely to be the issue.) just follow the ground cable to find it.
If the bottom rail is showing rust you will need to give it a good once over with a wire cup brush on a side grinder
I use a brass wire brush in my cordless drill with generous amounts of deoxit to polish the copper strip AND the lower head rail as this where the ground block slides
BE GENEROUS with the DEOXIT!! I but this stuff by the case.
Re assemble and adjust as per the manual. You should be operational. takes about 2 hours to do the whole process for me.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #14 on: October 31, 2019, 08:33:25 PM »
Yup, it's easy to overlook the ground that slides along the bottom rod.  I have never had any problem whatsoever with mine, but it is there.
Offline brooksmill
  • retired!
« Reply #15 on: November 01, 2019, 11:58:34 AM »
OK been doing some elec testing. Reading 12.5 v across fuse links and same off left side of solenoid but right side of solenoid nothing (one going to spring loaded block) Thinking could be bad solenoid. What say you? Thanks for all the help. I know I could call woodmizer but don't have cell service at the mill
« Reply #16 on: November 01, 2019, 12:11:08 PM »
Is the key in the on position AND is there voltage to the switch terminal of the solenoid coming from the key? If that line is dead the solenoid will not close and no power through. Could be the switch or a fuse/breaker?
Check to make sure you have power through the key switch to that line and terminal on the solenoid.
Id have to check the wiring diagram in the manual to be positive where to check for that.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #17 on: November 01, 2019, 12:26:01 PM »
You can temporarily jumper across that first solenoid with a jumper cable.  Heck, you could even bypass the contact strip.
A hot jumper cable can be your friend working backwards from the hydraulic pump.
« Reply #18 on: November 01, 2019, 01:08:40 PM »
MM suggesting  a good and quick short term method to test things. You could just take short  wire to cross from the hot side of the solenoid to the switch terminal to see if the solenoid is working. If it is working that way, your problem will be between solenoid switch terminal and the key switch.
Offline brooksmill
  • retired!
« Reply #19 on: November 01, 2019, 04:19:32 PM »
Jumped across solenoid and hydraulics worked but my jumper was smoking so what could be my problem. Is solenoid bad? Not sure what to order
lt40 hydraulics stop working
Started by widfam on Sawmills and Milling
Last post December 27, 2015, 05:06:37 PM
by Chuck White
Lt70 hydraulics quit working
Started by just_sawing on Sawmills and Milling
Last post February 13, 2013, 07:48:26 PM
by just_sawing
Hydraulics on LT40
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 29, 2016, 09:11:18 PM
by paul case
lt40 hydraulics
Started by Mcwhorter111 on Sawmills and Milling
Last post March 03, 2017, 08:53:29 AM
by paul case
