Author Topic: My new lights  (Read 961 times)
Offline Percy
  • Resident trouble maker
My new lights
« on: November 01, 2019, 09:32:07 AM »
I bought an 8 pack of led shop lights from Princess Auto...29.95 a light......I should have bought about 20....these were a good deal and were on sale....as Inspector Closeau said in the Pink Panther..."Not anymore"...Regardless, they work really well....Now I can work more stupid length shifts than I am right now.... :D :D :D
Offline highleadtimber16
  • Learning Everyday
Re: My new lights
« Reply #1 on: November 01, 2019, 09:45:32 AM »
I got pretty well the same lights from costco. I put 6 of them above my mill. I can't work without them now.
2011 Wood-Mizer LT 40 hyd w/ 12' Extension, Patrick Model A Loader, 75 Hitachi, Stihl 461, 2X066, & ms 192
Cutting Old Growth Cedar from Queen Charlotte Islands.
Offline Dakota
  • Swing'en in South Dakota
Re: My new lights
« Reply #2 on: November 01, 2019, 10:14:58 AM »
I like em.
Dave Rinker
Offline Resonator
  • Board Footage and Cord Woodage
Re: My new lights
« Reply #3 on: November 01, 2019, 10:28:57 AM »
If you've ever had to work under dim flickering fluorescent bulbs on a sub-zero morning, then you will truly appreciate LED's. smiley_sidelightbulb
Offline Southside
Re: My new lights
« Reply #4 on: November 01, 2019, 10:34:42 AM »
Funny timing. I put in 70,500 lumens worth of LED's just this past week.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: My new lights
« Reply #5 on: November 01, 2019, 10:46:55 AM »
Close Encounters of the orange kind.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline rjwoelk
    • countrysidefirewood
Re: My new lights
« Reply #6 on: November 01, 2019, 02:33:48 PM »
I have similar ones in my shop we just installed. Lots of light.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline dustintheblood
  • Home in the woods
Re: My new lights
« Reply #7 on: November 01, 2019, 02:40:37 PM »
Literally walked in from the shop as we finished installing new LED's on the forwarding trailer.  Four-up bar with 120 degrees total, mounted at the base of the boom so it's always pointed where my eyes are.
Mill's next to get the sunlight at night treatment ... off to Princess Auto this evening after a timmies stop.
Case 1494, Igland 4001, Hardy 1400ST, WM LT40HD, WM Edger, ICS DH Kiln, plus other toys - cause well - gotta have something to play around on
Offline Nebraska
  • I'm new! Lurked for quite a while, learning !
Re: My new lights
« Reply #8 on: November 01, 2019, 03:20:31 PM »
You mean there's a better way than holding my cell phone on flashlight in  my teeth to read the scale and  set my last two cuts in a cant I didn't get finished before dark..... I wish I was kidding.. ::)
Offline Southside
Re: My new lights
« Reply #9 on: November 01, 2019, 03:33:36 PM »
Been there, done that. I find it works better if you clip the belt clip to your shirt collar actually.
Online Old Greenhorn
Re: My new lights
« Reply #10 on: November 01, 2019, 03:56:59 PM »
I thought I was the only one that did that  (I don't have a cell phone so I use a flashlight). I can't wait until I move the mill and have commercial power available for some lights. Right now I sometimes have to use a flashlight during the day if it's cloudy because the mill is under a huge tarp.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline wodbutchr
Re: My new lights
« Reply #11 on: November 01, 2019, 08:47:29 PM »
Anybody installed 12V LED on the mill head, not to cut the log clamps for those who mill by night?
LT40 manual, L190 NewHolland, Homemade Log Cart "LogMob"
Andre
Timber Frarmer
Offline Southside
Re: My new lights
« Reply #12 on: November 01, 2019, 09:14:38 PM »
Re: My new lights
« Reply #13 on: November 01, 2019, 09:15:55 PM »
I think about this all the time, just have not had time to do it. I need to get a battery and get it done.
Offline wodbutchr
Re: My new lights
« Reply #14 on: November 02, 2019, 07:50:23 PM »
Southside: Looks good.
Got more pics on how you attached it? 12V Wiring from the mill?
Has this been discussed on the forum before?
Thx
Andre
Timber Frarmer
Offline Southside
Re: My new lights
« Reply #15 on: November 02, 2019, 10:30:48 PM »
All the wiring is in loom so a picture would not do much.  But here is a diagram.  I used the 12v + laser wire (#1207 on my mill) as a trigger source to feed into a waterproof relay, this way I can turn the lights on or off from the DCS station, and there is no significant draw onto that circuit.
The lights come in quite handy even during the day if there is a shadow or if it's overcast, one pair mounted on the back of the head and one on the front. (I only had half on them on there when I took the photo).  It completely eliminates any dark spots even from 36' away.
If you have a walk along or a Command Control model the same thing could be done just using a toggle switch rather than tying into an existing circuit for a trigger.  I didn't want to have to walk up to the mill and flip a toggle so I went the route I did.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: My new lights
« Reply #16 on: November 03, 2019, 07:18:28 AM »
Sweet setup all of you guys. Those LED shop lights look like a lot of bright for the money.
HobbyHardwoodAlabama.com
Offline wodbutchr
Re: My new lights
« Reply #17 on: November 04, 2019, 12:12:21 AM »
Southside: Thanks for the info, something to chew on...
Andre
Timber Frarmer
Online Crusarius
  • Lost in....
    • RockModified.com
Re: My new lights
« Reply #18 on: November 05, 2019, 02:49:04 PM »
I had a ton of t8 fixtures that had bad ballasts in them. I just bought the t8 LED tubes in bulk from amazon. The last batch I bought cost me $4.00 per bulb. I rewired the lights to eliminate the ballast and powered them on one end. They are so much brighter, instant on, and instant bright. Worth every bit it took to do it.
question
LED Lights?
Started by sandhills on General Board
Last post May 31, 2017, 10:27:39 AM
by trapper
Uh Oh...Now, I have lights
Started by tcsmpsi on Sawmills and Milling
Last post January 29, 2007, 12:04:17 PM
by Robert Long
Christmas Lights
Started by Tom on General Board
Last post December 23, 2007, 08:08:03 PM
by SwampDonkey
What's with these flourescent lights.
Started by SwampDonkey on General Board
Last post August 28, 2006, 03:05:23 PM
by beenthere
