Author Topic: cutting wedges ala Jim Rogers  (Read 609 times)
Offline 47sawdust
« on: November 01, 2019, 11:53:53 AM »
I found myself having to cut some wedges for a home project.After spending some time over thinking the process I decided to use the forum search and see how others had done it.
Thanks to all who have gone before me and posted here.I settled on Jim Rogers approach  and in short order had 20 hemlock wedges.
Thanks Jim and everyone else as well.
Mick
Offline trapper
Re: cutting wedges ala Jim Rogers
« Reply #1 on: November 01, 2019, 12:10:31 PM »
picture is worth a thousand words  I like that idea
stihl ms241cm ms261cm  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: November 01, 2019, 12:22:01 PM »
   I can't tell from the picture but I assume you are cutting multiples at one time. The ends don't appear to to be cut at a 90 degree angle but I assume you put them on a 4X4 and marked 90 degrees from that point.
   Thanks for posting. Looks straightforward and simple and I like simple.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: November 01, 2019, 12:28:42 PM »
Of course the term "wedge" can be interpreted differently depending upon what the intended product is.   ::)   :P
Offline 47sawdust
« Reply #4 on: November 01, 2019, 12:34:11 PM »
They are cut one at a time as I didn't want to go to the trouble of building an involved jig.Each one is clamped.The 10° angle angle is for a specific purpose,hence not square.They are 7''x9''.
Mick
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #5 on: November 01, 2019, 01:06:20 PM »
You're welcome, and each use can be different.
Jim Rogers
Offline GAB
« Reply #6 on: November 01, 2019, 04:13:21 PM »
I cut some approx. 5' long wedges to level a bathroom floor.
The first 2 or 3 went in the firewood pile.
Got better after that.
GAB
Online DYank
« Reply #7 on: November 01, 2019, 05:42:10 PM »
When I cut wedges they are not planed. ::)
« Reply #8 on: November 01, 2019, 08:48:53 PM »
   Yeah, I have cut my share of long wedges without any prior planning too. Now who raised that toeboard while I wasn't watching? :D
Offline pineywoods
« Reply #9 on: November 04, 2019, 11:47:16 AM »
I cut a few for use as wheelchair ramps..Use where the rise is a few inches to a foot. Beats trying to fab up a structure. Just lay them in place , no attachments.
Offline DWyatt
« Reply #10 on: November 04, 2019, 01:59:55 PM »
I just cut a 2" tall x 10' long wedge this weekend out of some beautiful Red Oak.  >:(
Cutting large wedges on my WM
Started by Jim_Rogers on Sawmills and Milling
Last post July 01, 2011, 09:22:07 AM
by derhntr
cutting round stock for wedges
Started by ljmathias on General Woodworking
Last post May 10, 2008, 09:00:49 PM
by Ironwood
Jim Rogers and I
Started by Magicman on Sawmills and Milling
Last post June 03, 2013, 12:35:19 PM
by taylorsmissbeehaven
New member, and Thanks Jim Rogers
Started by alongjordan on Timber Framing/Log construction
Last post December 26, 2011, 03:38:40 PM
by Magicman
