Author Topic: CAD software for timber framing  (Read 12621 times)
Offline rcolmansr60
  • Still have 10 fingers
Re: CAD software for timber framing
« Reply #20 on: April 10, 2005, 06:57:21 PM »
Joey,
   Which TurboCad did you use ? The Professional or the Delux? How did you like the Chief Architect for TF?
Dick
Kirk_Allen
  • Guest
« Reply #21 on: April 10, 2005, 11:21:40 PM »
I downloaded the Dietrich's program but have to say, its not easy to use or figure out but thats coming from a person who has never done any CAD work.
Looks like it will do a lot but I cant even figure out how to draw a straight line a specific lenght.  If I could get that part down I might have a chance.
I have done some work on a program called Vellum 3d.  It was very easy to learn and use but its not designed for construction at all.
Offline TexasTimbers
    • Dovetail Spline Jig
« Reply #22 on: April 11, 2005, 11:56:32 AM »
Joey,
Thanks for this info. It's refreshing to know that in a world where EVERYTHING seems to have a price tag, some things are still free. Maybe as an introductory to their better software, but that's something I always consider when I elect to do business with someone.
I don't expect a free lunch but sometimes it's good business not to try and "nickel and dime" people to death.
Great tip - thanks. KJ
P.S. Hows the shop coming?
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #23 on: April 11, 2005, 03:19:07 PM »
Here is a drawing of a frame that I created in 2002 using floor plan as part of TurboCAD
It can be done but it's just for visualization and not a true timber frame drawing.
Jim Rogers
Offline JoeyLowe
  • "In the German Tradition"
« Reply #24 on: April 13, 2005, 10:24:38 PM »
Hi Dick:
I'm currently using TC version 11. but I saw it demoed with V8 Professional.  Chief Architect is also a good program and I highly recommend it.  It's a little pricey at just under $1800, but it does a good job of cost estimating and rendering too.
KevJay:
The shop is coming along just fine!  Been real busy here.  We have sold two frames locally and a couple over in Mississippi.  I decided that to keep up the pace, that I needed to drift a little from traditional timber framing and venture into using some of the engineered connectors available.  Two such animals that have greatly speeded up my production are LogHogs and Timberlinx coonectors.  Again, I highly recommend them.
Regarding the use of floor plan and TurboCad, fully rendered photo realistic drawings are well within the capabilities of this software.  In a few days, I will post a couple of renderings so that yall can see it's capabilities.  Many designers use both of these programs to do just that.  Since very few, (if any) designers generate "working drawings" or "shop drawings", these programs can be used to create as "true" a drawing as any other program.  Granted they don't automatically draw out a joint and then use that joint to make the connection, but who really cares since joinery is subjective anyway. ;D
Joey Lowe
"Working towards perfection has to be a part of anything one does.  You've got to put yourself into it." ... Sam Maloof (chairmaker)
framing software
Started by timh on Timber Framing/Log construction
Last post January 29, 2010, 07:21:11 AM
by Jim_Rogers
Reinforced Timber Framing / Mock Timber Framing?
Started by Stuart Caruk on Timber Framing/Log construction
Last post January 14, 2015, 08:47:15 PM
by Gumneck
Software for round timber cutting
Started by ukraineholz on Forestry and Logging
Last post January 28, 2010, 03:52:03 PM
by ukraineholz
Does post and beam change the use of Green Oak timber, v true timber framing?
Started by MbfVA on Timber Framing/Log construction
Last post September 04, 2017, 09:36:55 PM
by Don P
