Tally-I/O
Author Topic: Any ideas on what this is?  (Read 1844 times)
Offline Kainkelly
Re: Any ideas on what this is?
« Reply #20 on: November 18, 2019, 12:57:39 AM »
Something used from a Musket as Ammo back in the Day,
Probably entered the tree first then sawn into a beam.
Always fun too investigate odd objects.
I was thinking the same thing, if you look at the bottom it looks almost as if it broke off of something.
It certainly is broken off, on three sides.  I don't understand this.
Any chance this beam could have been from a blacksmith, or any sort metal/machine shop? It's possible this is hardened steel that got stuck with a (most likely sledge hammer) that would also explain why it's broken on three sides if it came off a corner.
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #21 on: November 18, 2019, 05:29:07 AM »
It looks like a broken gear tooth to me.
     Not a round gear, but maybe part of a gear rack.  That's the best idea I've heard yet!  If it shattered, it could've hit the beam hard enough to embed itself.
WoodMizer LT50HDD51-WR
Lucas DSM
Offline OldMasterTech
  • I'm new! (I wish!)
« Reply #22 on: November 18, 2019, 08:31:04 AM »
Are you friendly with any local scrapyards? Take it to one with an alloy analyzer and ask to test it.
Do it while you're selling scrap or there will probably be a charge.
All gave some ** Some gave all
Never forget
Offline Nomad
  • Member
« Reply #23 on: November 18, 2019, 11:17:11 AM »
Not a bad idea either.  Does it destroy the sample?  How big a sample do you need?
Lucas DSM
Offline kantuckid
« Reply #24 on: November 23, 2019, 08:27:22 AM »
A magnet test would say more! If it's hard I really doubt even a frontiersman would have shot it in their prized possession rifle!!! My guess is a shot in the wind that it's a machinery fragment, best guess is part of a circle saw tooth locking part.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #25 on: November 25, 2019, 08:55:29 AM »
Definitely try the magnet test.  That will tell a lot quick and easy.
I don't work in a scrap yard, but do run a metallurgy lab.  When asked how big, I show them a bit that is half the size of a BB and say that I can work with smaller, but it is fast and easy if it is at least that big. Then I can use the handheld gun instead of the scanning electron microscope.
I doesn't harm the sample to take a surface reading.  You shoot it with some X-Rays and the meter looks for the energy decay signature to determine the element(s).  (I mostly work with alloys.)  Takes about 5 seconds for most metals.  If I have to grind/polish to get through rust, carbon, etc. to get to metal, that is the only harm done.
In the long run, you make your own luck good, bad, or indifferent. Loretta Lynn
Offline markdvsmo
« Reply #26 on: November 25, 2019, 09:57:38 AM »
Meteorite!
(I'm only half kidding.  Could happen.)
Offline Nomad
  • Member
« Reply #27 on: November 25, 2019, 11:40:42 AM »
     One of the first things I did was check it with a very powerful magnet.  It is non-magnetic.  Sounds like it's plenty big enough to test it.  No way this thing was ever fired from a gun.  Much too hard, and the shape is all wrong.
     Non-magnetic, barely reads on a metal detector, black, too hard to scratch with a file...  I'm wondering if it could be a piece of stone?  Shattered on three sides and the rest is a rounded surface, like the tooth of a gear.  Would be an oddly shaped stone, but possible I suppose.  Or maybe a piece of ceramic?  I'm mystified.
Lucas DSM
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #28 on: November 25, 2019, 02:37:34 PM »
If the piece you were resawing had been in a welding shop or was loaded on a truck or trailer, it could possibly be a piece of welding slag!
When a welder was chipping away some of the slag, it could have launched some distance and then being hot, imbedded itself into the wood!
Just a little thinking "outside the box"!  ::)
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Nomad
  • Member
« Reply #29 on: November 27, 2019, 12:15:01 PM »
Chuck, that's as good a theory as anything else I've heard, or come up with myself. :D
Lucas DSM
Offline Nomad
  • Member
« Reply #30 on: November 30, 2019, 05:01:06 AM »
    I believe I've figured it out. 8)  It is a piece of stone.  A piece of flat, water eroded stone like you'd skip across a creek or lake.  The profile matches perfectly.  How it got there?  I dunno.  Maybe the timber got dragged across some, or run over by a truck or something.  Need to find a mineralogist to verify that.
Lucas DSM
Offline Normang
« Reply #31 on: December 01, 2019, 09:19:17 PM »
Roswell??
Offline Nomad
  • Member
« Reply #32 on: December 03, 2019, 08:04:48 AM »
Lucas DSM
any ideas
Started by woodmills1 on General Board
Last post December 21, 2001, 04:22:53 PM
by L. Wakefield
Looking for ideas
Started by jim king on Forestry and Logging
Last post June 01, 2010, 08:37:49 AM
by wolfram
Any Ideas ?
Started by Autocar on Ask The Forester
Last post April 14, 2012, 07:58:55 PM
by Autocar
Looking for ideas
Started by Lko67 on General Woodworking
Last post January 21, 2019, 09:34:56 AM
by Lko67
