Tally-I/O
Author Topic: would like some advice  (Read 1146 times)
Offline Southside
Re: would like some advice
« Reply #20 on: November 29, 2019, 11:33:58 PM »
If regrinding is not a viable option then I would use them in cedar, or if you have that "suspect" log that just has to be sawn and the odds are decent of finding hidden treasure then open them up with a band that has no real other value to you, nothing to loose if by chance you do strike gold, or iron, steel, ceramic, etc.
Offline loghorse
« Reply #21 on: November 30, 2019, 09:43:41 PM »
if you use 4 degree for just red oak ,what wouid your set be?
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #22 on: December 01, 2019, 08:31:06 AM »
25 thou would be fine for a start, that's about where I set all of mine.  You can go more, you can go less, but .025" per side works fine.
HobbyHardwoodAlabama.com
064 advice
Started by HousewrightVA on Chainsaws
Last post August 22, 2012, 10:13:48 PM
by JohnG28
advice
Started by Old_Hickory on Chainsaws
Last post August 18, 2008, 10:13:11 AM
by zackman1801
Need a Little Help/ Advice....
Started by Dewey on Sawmills and Milling
Last post November 26, 2015, 09:43:59 PM
by Dewey
Advice please.....
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post October 26, 2011, 12:23:41 AM
by Brucer
