Tally-I/O
Author Topic: Resawing 6/4  (Read 1100 times)
Offline sealark37
Re: Resawing 6/4
« Reply #20 on: December 02, 2019, 02:03:44 PM »
The end use is the answer.  For paneling, it might work to the customer's satisfaction, not so much for the Sawyer.  If the purpose is flooring, quicker, cheaper, better is to buy more oak and plane it to thickness.   I will not divulge  how I learned this.    Regards, Clark
Online Brad_bb
Re: Resawing 6/4
« Reply #21 on: December 02, 2019, 07:28:04 PM »
@Pepe_Silvia , did you decide what you're going to do or tell him?
Online Pepe_Silvia
Re: Resawing 6/4
« Reply #22 on: December 02, 2019, 10:01:27 PM »
I told him it was ill-advised and probably would waste a board, but if we was set on it (he is) we could try one out and if he's happy with the result then we could do them all.
My plan is use some plywood to shim it up so that the halfway point is above the stops but not so high that the stops are ineffective.
I'll update with the results.
Offline barbender
Re: Resawing 6/4
« Reply #23 on: December 02, 2019, 11:07:03 PM »
I'm telling you man, make a resaw jig with hold downs and feed the material through the saw, not vice versa like normal.
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
Re: Resawing 6/4
« Reply #24 on: December 03, 2019, 08:17:24 AM »
     Got to agree with Barbender.  Spend an hour and make an Arky resaw jig.  Chain the saw head in place and push the boards through.
WoodMizer LT50HDD51-WR
Lucas DSM
Offline Ed_K
Re: Resawing 6/4
« Reply #25 on: December 03, 2019, 09:03:52 AM »
 I ended up having Rita push the saw while I pushed down on the board with a crowbar. It worked out ok but real slow trying to keep the bar close but not in the mills way.
 I did some garden stakes that started a 2"x 6"s and the boards I was given were wavy from 2" to 11/4" to start. I don't like reworking other's work  :o .
Ed K
Online Pepe_Silvia
Re: Resawing 6/4
« Reply #26 on: December 03, 2019, 09:26:09 AM »
Ok, I will take this advise.  May have to reschedule because I'm not sure I'll have time, but that's fine.
You severely overestimate how fast I can work.  ;D  The head has lockdowns built in so that should be helpful at least.
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Resawing 6/4
« Reply #27 on: December 03, 2019, 12:58:25 PM »
Why don't we use carbide tipped bands for general milling?
I did that. was great. Up until I found 2 drywall screws in a 22" walnut. that was a costly mistake.
Offline Rhodemont
  • Logging and milling just a hobby
Re: Resawing 6/4
« Reply #28 on: December 03, 2019, 02:23:18 PM »
My most common boards are 1 x 6 oak for fencing.  I take as many as I can but always leave a 6x6 which is my second most common.  Figure can make more 1x6 from a 6x if needed but not a 6x from a 1x.  When I have resawn have learned to take 3/8 inch off the top which curls because dry at surface and still wet interior.  Then flip the bottom last 1 1/2 board and take 3/8 outter surface off it as well.  End up with five nice 1x6 rather than four nice boards and two potato chips when I tried to get all six. (going after that last one still makes my heart beat even though I know the blade will clear the stops)
Woodmizer LT35HD    JD4720 with Norse350 winch
Stihl 362, 039, and now an Echo CS-2511T
Resawing
Started by jim king on Sawmills and Milling
Last post May 03, 2010, 12:20:00 AM
by Meadows Miller
What is the best bandsaw to get for resawing?
Started by oakiemac on General Woodworking
Last post January 25, 2013, 06:37:50 PM
by Clark
Resawing Chestnut!
Started by vahighlander on Sawmills and Milling
Last post August 14, 2010, 09:43:36 AM
by John Mc
Resawing old beams
Started by W5E2J on Sawmills and Milling
Last post April 12, 2019, 07:30:16 PM
by W5E2J
