Tally-I/O
Author Topic: Sawmill recommendations  (Read 305 times)
Offline Aprilinnewyork
« on: November 28, 2019, 12:42:22 PM »
 ??? Recs for Sawmill in south central Virginia/north central North Carolina to rough cut 3000 sq/ft pine 1 plank flooring. Random width. They provide logs. Thank you!
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Sawmill recommendations
« Reply #1 on: November 28, 2019, 12:48:35 PM »
   Go to the home page on this site and under the Extras tab is Find a Database. Select service as portable sawyer and enter your state and see if any of those are close enough. If nobody there, go to the Woodmizer.com site and under the Services tab you will see find a sawyer. Enter your state and check the list that shows up. Good luck. If I were closer I'd offer to do it but just a little out of my normal range.
« Reply #2 on: November 28, 2019, 01:48:33 PM »
Thank you for the tutorial, Ill search there. Like your sheep quote!
Offline Southside
« Reply #3 on: November 28, 2019, 03:13:52 PM »
It's what I do. PM me if you would like to discuss. 5% of the proceeds will go to the Forum if we do business.
PORTABLE SAWMILL -SMALL-RECOMMENDATIONS?
Started by 333_okh on Sawmills and Milling
Last post December 31, 2005, 06:54:06 PM
by 333_okh
First Saw MS 170 need recommendations
Started by ashtree on Chainsaws
Last post March 06, 2017, 10:18:41 AM
by DelawhereJoe
Recommendations?
Started by missvincent on General Board
Last post November 25, 2011, 08:58:34 AM
by Woodchuck53
ATV recommendations?
Started by ljohnsaw on General Board
Last post December 06, 2012, 01:24:37 AM
by jamesconley1962
