Tally-I/O
Author Topic: Preventing rust on planer infeed deck  (Read 390 times)
Offline dustintheblood
  • Home in the woods
« on: December 03, 2019, 11:42:33 AM »
Hi all,
Just picked up a new helical planer and it's setup in a large building that isn't heated.   Does anyone have tips or tricks on how to keep the rust away, especially on the deck?
Case 75C, Case 1494, RangeRoad RR10T36, Igland 4001, Hardy 1400ST, WM LT40HD, WM Edger, ICS DH Kiln
Offline dirtmotor
Re: Preventing rust on planer infeed deck
« Reply #1 on: December 03, 2019, 12:04:30 PM »
Might sound crazy but I use lemon pledge on mine .
I just spray and wipe every time I finish using it .
Offline Old Greenhorn
« Reply #2 on: December 03, 2019, 12:11:16 PM »
Always had this problem in my shop. I started cleaning the machines after use, the laying on a coat of WD-40. Just wipe it off before the next session. Never cover the machines with anything air/water tight. If you do cover them, keep it very loose and use cotton or canvas drop cloths. Covering can help keep the descending 'dew' from hitting the machined surfaces, but it needs to breath easily.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline Woodpecker52
« Reply #3 on: December 03, 2019, 12:52:58 PM »
car wax! made for steel and the outdoors!
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline A-z farmer
« Reply #4 on: December 03, 2019, 01:00:38 PM »
I agree with woodpecker on the wax.
Woodmaster recommends furniture paste wax such as minwax .They say to rewax it for six weeks then as needed.I put it on my 725 bed even though it is covered up by poly because our workshop is only heated during the day .
Offline moodnacreek
  • Sawin by the notches
« Reply #5 on: December 03, 2019, 01:16:32 PM »
Motor oil/wax. If you do eastern red cedar don't use wd 40.
Offline luap
  • Not as good as I once was
« Reply #6 on: December 03, 2019, 01:50:45 PM »
I agree with the paste wax. WD-40 has a solvent that is good for removing bug guts from your car and attracting fish to your lure and very short term lubricant but not a good metal protector.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #7 on: December 03, 2019, 01:53:54 PM »
I use Johnson paste wax or beeswax from Lowes.
The best way Ive found is to use a directional work light bulb and hang it over the planer, so that it lights the bed and keeps it slightly warmer than the surrounding area.  Then no water vapor will condense on it, and it will not rust.
HobbyHardwoodAlabama.com
  • Home in the woods
« Reply #8 on: December 03, 2019, 02:48:49 PM »
Definitely wax will be the way to go, but we're now down to daytimes of -15c (5f) and I'm pretty sure the wax won't adhere.
I'm leaning towards oil for the winter, and really like Yellowhammer's idea.
For sure it will be kept clean each and every time.
Offline btulloh
« Reply #9 on: December 03, 2019, 03:46:01 PM »
Balistol
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #10 on: December 04, 2019, 08:21:09 AM »
I use this to keep the planer bed slick.  It helps to prevent rust, too.
Shop Tools and Machinery at Grizzly.com
Offline markdvsmo
« Reply #11 on: December 04, 2019, 08:25:58 AM »
I've had pretty good luck with Boeshield T-9.  Needs to be reapplied every few months, but it's a lot easier than messing with paste wax.
« Reply #12 on: December 04, 2019, 08:37:46 AM »
My stuff is out in an non climate controlled shed so it really sees temperature and humidity swings.  When the temps start changing and the humidity climbs and I see all the condensation forming on the cold metal everywhere else, the lights are on and the machinery is warm, dry dry and cozy.
At some times of the year, especially early spring, I use floodlights or sunlamps, the ones for keeping animals warm in place of incandescent bulbs.  They provide lots of light to work with, and it can be a cold, nasty humid morning and when I turn on the equipment, the belts, bearings, oil, everything is a nice warm temerpature and the machine lights right up with no squeeling or belt slips.  The deck is shiny and there is no wax residue.
I do use wax, but Ive seen heavy condensation form on the machinery in just a few hours without the lights shining in it, especially in Spring.
Offline btulloh
« Reply #13 on: December 04, 2019, 08:50:51 AM »
YH has a good plan with those lights.  I should start lights on my stuff to prevent the condensation.  Just requires a little more discipline on my part.
Markdvsmo mentioned Boeshield T-9 which is also a very good product and a good thing to have in the arsenal.  I have yet to determine whether the Boeshield or the Balistol is better, but they're both good and very similar.
Condensation is a constant battle for me.
HM126
Offline doc henderson
« Reply #14 on: December 04, 2019, 08:59:16 AM »
I have made thousands of engraved coasters, but people still sit cold aluminum cans on my table saw, as it is surrounded by stools to sit on.  after hours of course!   smiley_beertoast
log Splitter infeed table
Started by Maplekid on Firewood and Wood Heating
Last post February 11, 2012, 01:42:34 PM
by thecfarm
Infeed bunks for logs
Started by jim blodgett on Sawmills and Milling
Last post December 09, 2007, 10:46:53 PM
by AusLJW
Rust Reaper takes on NZ Sulphur Rust
Started by HSV on General Board
Last post November 06, 2006, 02:46:59 PM
by HSV
infeed/outfeed table, height adjusting
Started by amberwood on Sawmills and Milling
Last post July 05, 2007, 08:57:37 AM
by amberwood
