Tally-I/O
Author Topic: Best way to use tractor with winch/forwarder trailer combo ??  (Read 6315 times)
Offline Madman_Mark
This is a follow up to one of my previous posts.
Some of you suggested that I should get a forwarding trailer/loader to use with my tractor and winch.
I've been looking into it and it sounds like a good idea.
I've never used one so I need lots of info on the best ways to operate.
Is it best to winch all the trees to my skid road and then unhook the winch and hook up the trailer, or just travel across everything (which I prefer not to do) to each pile of wood that I cut as if cutting for a larger forwarder.
Give me some advice please.
Thanks.
Offline Ed_K
Re: Best way to use tractor with winch/forwarder trailer combo ??
« Reply #1 on: March 06, 2005, 08:58:25 PM »
 I have my trailer hooked right to the winch. I plan my skid roads, then cut them out being careful to cut stumps low, so they won't punture my tires. Then I start at the back of the lot and cut trees. Winch the logs to the trailer, pick them up with the loader, pull it up and cut off a piece. Load on to the trailer and get another piece. Keep going till I have a load and out I go.
 Depending on how big the trailer is determines how big the tractor needs to be. Under 1/2 cord needs 3000# tractor. 1/2 to 1 cord needs at least 7000#.
Ed K
Offline tnlogger
« Reply #2 on: March 06, 2005, 09:31:33 PM »
 like ed_k said  :D
 here is a pic of his rig.
gene
Offline jrb34
  • I don't get paid enough to edit my profile
« Reply #3 on: March 07, 2005, 05:52:13 AM »
I can't quite see how the trailer attaches to the winch. Do you have a closer pic? I've looked for places on my Fransgard I could mount a hitch, but I don't see anything rugged enough to weld a receiver to.
JRB
Offline Ed_K
« Reply #4 on: March 07, 2005, 08:00:53 AM »
 I have a 2" ball hitch where the bottom sheave goes. I am planning on putting in a Reese coupling to get the ball hitch a little lower.
Ed K
Offline tawilson
« Reply #5 on: March 07, 2005, 11:53:21 AM »
I've been talking about putting hitch on my Farmi for a year now and just have't done it. Are you going to cut a hole in the blade to slide the reciever in  and weld it in place? I've been into some welding and fabbing projects the last few weeks and maybe it's time to do this one.
2017 LT40HDG35 WIDE
Offline OLD_ JD
« Reply #6 on: March 07, 2005, 12:21:41 PM »
have a look at this link... ;)
http://www.payeur.com/
canadien forest ranger
Offline Madman_Mark
« Reply #7 on: March 07, 2005, 08:05:47 PM »
tnlogger, can you post a close up of the hitch on your winch ?
Anymore advice on my previous question from anyone ?
Thanks again.
Offline tnlogger
« Reply #8 on: March 07, 2005, 09:21:15 PM »
mark thats ed_k tractor and winch he might have a lager picture laying around some place
 that he can send ys
gene
Offline woodmills1
  • the truth shall set you free
« Reply #9 on: March 08, 2005, 07:29:02 AM »
I have a Kioti metavic package from payeur, it serves me very well.  The winch is hydraulic and built into the head board.  I winch up to the skid roads and then cut and lift into the trailer with the loader.
Offline Ed_K
« Reply #10 on: March 08, 2005, 09:06:14 AM »
 Be sure when you weld in a box type hitch, that it won't be in the way if you ever have to drop your clutch or drum out. I will have to offset mine some, I realised this when I had trouble with the drum and clutch sticking during real cold temps.
 I'll get a picture of the hitch as it is now, after it stops raining.
 Something else to think about is if your on hillside land, the hitch should be able to rotate 180 degs, incase the trailer tips over, it won't tip your tractor. Mine's not set up this way, the reason for wanting to change it.
Ed K
Offline JN68
« Reply #11 on: March 08, 2005, 09:21:27 PM »
HI ; i have a fransgaurd v4000 winch, 405 patu loader on home made power trailer. I winch everything to a main skiding road.saw the trees too what is needed. Unhook the winch (does not take anytime) hook the power trailer on and forward the logs,pulp,hardwood too the yard. The reason that i do it this way is i have seen what happens too the 3 point hitch arms when toooo! much weight are placed on them. Add the weight of the winch plus the loader,trailer, load= trouble. That's is just my own way i look at it. ;) JN
Offline slowzuki
  • Still learnin'
    • On the Farm
« Reply #12 on: March 09, 2005, 08:19:36 AM »
A fellow here has an older winch with the legs.  His forwarding trailer hooks under the winch when the 3 point is up all the way and it seems to clear well.
I think I'd prefer the forwarding trailers with the built in winch.
Offline Ed_K
« Reply #13 on: March 09, 2005, 02:36:43 PM »
Here's a picture of my hitch setup.
 It would be better to have a swivel type of hitch in case the trailer ever tipped over.
Ed K
Offline Madman_Mark
« Reply #14 on: March 09, 2005, 10:06:00 PM »
Good picture, that winch looks quite a bit like mine, it's a Farmi 351.
Good advice about the hitch being able to rotate, I didn't take that into consideration.
That would be alot of weight on the 3PH though.
How much does it affect the trailer when you have to lower the winch to the ground when winching in trees ?
Would be nice to have a winch right on the back of the trailer.
Offline Woodhog
« Reply #15 on: March 10, 2005, 02:10:10 AM »
Here is an interesting article on a winch forwarder combo..
http://www.findarticles.com/p/articles/mi_qa3764/is_200106/ai_n8957512
Offline Ed_K
« Reply #16 on: March 10, 2005, 08:02:37 AM »
 Woodhog, that an intresting article. I'd like to see it working. Anyone know of someone in the new england area using one?
Ed K
Offline Bro. Noble
« Reply #17 on: March 10, 2005, 10:24:09 AM »
My son and I work together,  we use a FWD tractor with forks on the front, and a winch behind.
He pulls a log wagon behind the winch and I take a log truck.  I cut and limb and he skids and bucks and loads the wagon and truck.  It works good for us and didn't cost much.
Offline hillbilly
« Reply #18 on: March 14, 2005, 05:04:24 AM »
         Noble does your son load the truck w/the tracto or do you have a loader on the truck?
                   HILLBILLY
Offline Bro. Noble
« Reply #19 on: March 14, 2005, 02:01:46 PM »
He loads the truck and wagon with the front end loader.
Come on over and take a look sometime------bring your gloves :D :D
Chainsaw/forwarder combo
Started by gman98 on Forestry and Logging
Last post August 14, 2016, 06:23:10 PM
by Corley5
Timber Pro TF 830 Combo Forwarder
Started by thecfarm on Forestry and Logging
Last post February 20, 2012, 05:45:34 PM
by Maine372
Wood trailer/log splitter combo
Started by bartman on Firewood and Wood Heating
Last post December 20, 2014, 09:41:20 PM
by clww
want a combo pintle/bar hitch on tractor drawbar
Started by Bobcat_pa on Forestry and Logging
Last post March 25, 2004, 03:58:33 PM
by karl
