Author Topic: no dry kilns  (Read 2211 times)
Offline hillbilly
no dry kilns
« on: March 26, 2005, 08:36:23 AM »
            Ive been looking for some one in our part of the country to dry kiln lumber when I have some that I need to have done and Ive only found a couple.One of them has their own furniture and cabinet shop in the front door ,Ive heard that they have mystery lumber to just dissapear  ::)I wonder where it went ?
 I am thinking of putting in my own little kiln for small amounts 500 to 1000feet max Ill admit Im greener than grass on this sub ject I could use all the advice and info anyone cuold give me ,books to read ANYTHING would help.
             hillbilly
Offline WH_Conley
  • I need to tide my profile!
    • Stone Hill Hardwoods
Re: no dry kilns
« Reply #1 on: March 27, 2005, 09:11:39 AM »
Where is your part of the country?
Bill
Offline Brad_S.
Re: no dry kilns
« Reply #2 on: March 27, 2005, 10:06:14 AM »
The Nyle operators manual for an L50 might be worth purchasing whether you're thinking about a Nyle or not. The one I got with my used L200 had more than just what button to push and what to set this or that sensor to. It had good info on how to dry, why to dry and what to watch out for when drying.
The infamous Wood Doc at that other wood site always refers this type of question to some book that I don't recall the name of at the moment. You may want to take a look at  the archives over there.
Offline hillbilly
Re: no dry kilns
« Reply #3 on: March 27, 2005, 10:23:18 AM »
                  Southern Mo about 11/2hrs from ark and about 15mins from the CURRENT RIVER ;D AND about 1 hour from the area that noble lives in .There are several dry kilns but they stay packed full of there own material [flooring plants] so those are usualy out of the question.
                   Thanks Brad Ill try to get a hold nyle for their booklet.
HILLBILLY
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: no dry kilns
« Reply #4 on: March 27, 2005, 11:58:41 AM »
look into building a solar kiln.  I do all of this stuff with a friend of mine, we split the cost of a lot of stuff other than major equipment (I own the big chainsaw, and the sawmill, etc), but we split the cost of our kiln, we had around maybe $500 in it.
They are slow, but they work.  I'm currently contemplating making a new kiln from wood we saw up, I have a lead on a big locust tree (actually 3 if they haven't burned them up)...  I think I'm going to make the whole thing from that, I figure locust should last a while, especially if painted and whatnot...
the one we have now will just fit a 8'6" board, the one I want to put on my lot will be longer, to facilitate loading long boards.
my kiln pictures are here:  http://www.forestryforum.com/gallery/thumbnails.php?album=237
lots of dull bands and chains
Offline hillbilly
Re: no dry kilns
« Reply #5 on: April 04, 2005, 05:41:01 AM »
              Those are some pretty good pics Dan ,what are the black tubs that you have on top of the lumber ,Im thinking that they are weight ? Tell me some more about your dry kiln ventilation ect.
                 thanks HILLBILY
Offline Dan_Shade
Re: no dry kilns
« Reply #6 on: April 04, 2005, 03:28:40 PM »
I went to walmart and got the cheapest rectangular flower planters I could find, and filled them with concrete, I guess techically you could use cardboard boxes as forms too...
my vents are foundation vents, I got them from lowes, I used an attic vent fan for the fan.  I only used one, it may need two, I really don't know how to tell if I need two or not.
I have the material to put the second roof layer on, I need to do that.
Are kilns Always necessary?
Started by Rod Yowell on Drying and Processing
Last post November 02, 2013, 06:54:04 PM
by GeneWengert-WoodDoc
Vac Kilns???????????
Started by Dale Hatfield on Drying and Processing
Last post November 27, 2005, 02:58:04 PM
by Den Socling
Vac Kilns Again
Started by DragonsBane on Drying and Processing
Last post January 09, 2006, 03:02:33 PM
by Den Socling
How many have Kilns?
Started by Rick-Wi on Sawmills and Milling
Last post August 31, 2002, 11:48:49 AM
by Brian_Bailey
