Author Topic: ;)husky 365?  (Read 2337 times)
Offline ranger
;)husky 365?
« on: June 27, 2002, 11:22:30 PM »
would like to get opinions about the 365 for use as a falling saw. mostly falling white spruce up to 32" but average tree diameter of 15" to 24" butt diameter. would rather fall with a 372 or 385 but own the 365 now with 28" bar.
Offline Kevin
Re:  ;)husky 365?
« Reply #1 on: June 28, 2002, 05:16:17 AM »
Ranger, your 365 should be fine.
A 28" bar is a bit much for that saw in order to keep the rpm up but it`s a good 15-20" tree size saw.
If you just have a few larger trees to cut you should be ok.
Offline DanG
Re:  ;)husky 365?
« Reply #2 on: June 28, 2002, 07:49:00 AM »
Kevin, I know that running too much bar will slow things down, but does it cause other problems? I used to have a 36 inch bar for my old Poulan 3400, and it was slow as Christmas, but seemed to work ok, otherwise.
Offline Bro. Noble
Re:  ;)husky 365?
« Reply #3 on: June 28, 2002, 09:11:57 AM »
ranger,
Try a 'skip'chain with your underpowered saw.  It will help you keep up your rpm's.  Use the shortest bar that you can get by with because of cost, handiness and power.  Just my experience.
Offline Kevin
Re:  ;)husky 365?
« Reply #4 on: June 28, 2002, 02:20:08 PM »
Dan, you`re causing the saw to work harder which isn`t good for it over long periods of time.
Husky Prestique 61 (1980) Vs Husky 562XP
Started by Mikeinkaty on Chainsaws
Last post June 13, 2016, 06:09:49 AM
by SawTroll
Husky 346 XP
Started by eurosteve on Chainsaws
Last post September 08, 2014, 11:37:28 AM
by Hitchcock Woods
Husky 61
Started by petefrom bearswamp on Chainsaws
Last post June 16, 2016, 06:16:32 AM
Husky 350
Started by kenskip1 on Chainsaws
Last post September 11, 2005, 06:53:53 PM
by Striker
