Author Topic: Sawing timbers.  (Read 1548 times)
Offline Camp Run Farm
Sawing timbers.
« on: May 23, 2005, 06:14:41 AM »
Ok, I am going to let you know up front that I know absolutely nothing about this subject, but from the posts I have been reading this is the place to get the information.  I really enjoy reading this.  I just got an LT40 and have been cutting some hemlock siding for an out building.  I am interested in cutting some 4" x 8" x 10' timbers to build a pavillion.  Is it better to center the timber in the log or can you also cut them from the sapwood?  I don't want them to twist.  Any information will be appreciated.   Thanks,   Ed
Offline Minnesota_boy
  • Some like 'em short, but I prefer looong!
Re: Sawing timbers.
« Reply #1 on: May 23, 2005, 07:26:02 AM »
It depends. :D
Actually it does depend....on the species and individual trees.  If you make them from any hardwood, center the heart.  Some softwoods it doesn't matter too much, others it will matter a lot.  Tamarack won't matter a bit, it will twist and warp if it feels like it, otherwise not.  I've had good luck with sawing beams from outside the heart on white and red pine, but I wouldn't try it with jack pine as I know that will warp.
Offline mike_van
Re: Sawing timbers.
« Reply #2 on: May 23, 2005, 06:44:46 PM »
I needed 26 4x8x14's for barn rafters, rather than saw 26 logs, I made 8x8's and split them in half.  Red Oak,  about half bowed while  being sawn in half.  I was making 13 trusses [12' collar tie too]  nailing 2x4's across the trusses for metal roofing.  In the end, the bow didn't matter here.
Re: Sawing timbers.
« Reply #3 on: May 24, 2005, 06:07:10 AM »
Thanks for the information, it is about what I was expecting.  I guess it is going to be better to be safe than sorry, cut the timbers with the heart centered and cut something else from the rest of the log.  Yesterday I was cutting some hemlock and cut one log without turning it and almost everything I cut started to twist immediately.
Thanks,   Ed
Sawing Used BC Fir Timbers
Started by Stephen1 on Sawmills and Milling
Last post April 05, 2012, 01:24:00 PM
by captain_crunch
sawing out timbers
Started by Dan_Shade on Timber Framing/Log construction
Last post July 07, 2008, 08:37:17 AM
by Jim_Rogers
Sawing timbers
Started by Camp Run Farm on Timber Framing/Log construction
Last post August 29, 2005, 02:18:38 PM
by Jim_Rogers
sawing old barn timbers
Started by climber2 on Sawmills and Milling
Last post December 27, 2015, 11:40:28 AM
by Bandmill Bandit
