Baltic Abrasives Technologies
Author Topic: Anyone Using A Log Wizard?  (Read 9134 times)
Offline twostroke_blood
  • I love the smell of Twostroke in the morning
« on: May 26, 2005, 05:57:51 PM »
I used this thing for the first time Saturday. Man, it really strips the bark off the log.
Offline Brad_S.
Re: Anyone Using A Log Wizard?
« Reply #1 on: May 26, 2005, 06:37:19 PM »
I agree, it sure removes bark, but IMO it's not a good all round sawmill debarker. When I really needed it to remove some caked on mud that was partly frozen, it wore the blades down to nubs while clearing enough for only one pass of the saw mill. I sold it shortly after that. If you're building a log home and need to strip bark, I bet it's a real time saver.
Offline Gilman
  • !eliforp ym tide ot deen I
« Reply #2 on: May 26, 2005, 07:47:49 PM »
Can you show us what the debarked log looks like?
WM LT70, WM 40 Super, WM  '89 40HD
Cat throwing champion 1996, 1997, 1999. (retired)
« Reply #3 on: May 26, 2005, 07:52:03 PM »
I didnt take any pics of the de-barked logs Gilman, but I'll be using it this weekend and I'll take some. ;D
Offline Bibbyman
    • Warden Sawmill
« Reply #4 on: May 26, 2005, 07:59:56 PM »
I had one for 4-5 and never got it out of the box.  Sold it.
What would help if it had carbide teeth (blades) that would last longer in the grit and dirt - the reason you need it in the first place.
Sawing since '94
« Reply #5 on: May 26, 2005, 08:06:02 PM »
If ya never took it out of the box how do ya know it doesnt hold up to the dirt and grit? :)  What are you using to strip away the mud,ice,dirt?   While were on the subject Bibbyman what are the best band blades out there with regaurds to holding up to dirty logs?
Offline Bibbyman
    • Warden Sawmill
« Reply #6 on: May 26, 2005, 08:59:35 PM »
Got me on that one.. :-[
At first.. I never got around to mounting it on a chainsaw.  Then I was told by others that a diet of dirt, grit, and rocks were hard on the blades - plus,  it was pretty hard work holding onto it.  I just took their word on it.  I then installed a debarker so I didn't need it.
We still "hack off" caked on mud and such with an ax or sometimes with a good whack with a splitting mall will bust off heavy caked on mud – then saw with a debarker.  (not nearly every log, mind you – just the real cruddy ones.)
We've been using Wood-Mizer DoubleHard exclusively for the past 5 years or more.  They appear to last longer than the blades of any manufacture we were using before.  We've not even tried anything else since then.
Sawing since '94
Offline woodmills1
  • the truth shall set you free
« Reply #7 on: May 26, 2005, 10:58:47 PM »
I have one mounted ona bar and have used it and it does do a good job.  Trouble for me is it really trows off the balance of the saw and gets to be a pain to use, but I do dig it out around iron removing time, or ifin I got a real nasty dirty log.
Offline Engineer
« Reply #8 on: May 27, 2005, 07:43:48 AM »
I got one mounted on an extra bar for my Stihl 025.  It's great in winter when the log is dirty/iced up/gritty/full of crud.  I usually don't bother in the summer and just scrape bark off with a sharp MUTT - one o' them ice scraper things on a long shovel handle.
One thing I did do is move the blades out a bit from the factory setting.  The first time I used it, I found that they stopped cutting after a very short time.  I was really disappointed until I moved the blades.  It takes a bit more effort to use now, but it seems to work a lot better.  I have probably stripped bark from maybe 30 logs with it, and haven't needed to sharpen blades so far.
I really wouldn't consider it as a substitute for a mill-mounted debarker, it's just too much effort.
Offline Stump Jumper
    • Hernden's Sawing & Excavating
« Reply #9 on: May 27, 2005, 08:19:06 AM »
a custom shortened bar will make this machine almost loveable ::) ::) balance is perfect on my 028  ;)
Offline mometal77
« Reply #10 on: May 27, 2005, 06:33:37 PM »
I have heard of using high pressure water to remove bark.  I could imagine using it on cedar logs not maple or fir. And after it has set for a few months.  And then use an old fashioned flat edge scraper to take the nubbins out.
Too many Assholes... not enough bullets...“I might have become a millionaire, but I chose to become a tramp!
« Reply #11 on: May 27, 2005, 09:18:02 PM »
O.K that short bar is too cool
Offline Tom_Averwater
  • Semi- retired Carpenter
« Reply #12 on: May 27, 2005, 09:35:13 PM »
I have one . It works good.  It's mounted on the same model saw you  have Twostroke_blood.
He who dies with the most toys wins .
« Reply #13 on: May 27, 2005, 10:02:21 PM »
That model 61 husky is maybe the best saw i ever owned, i took it out of the storage to do this job.I forgot what a nice saw it is. Its almost too much saw for the log wizard
Offline woodmills1
« Reply #14 on: May 28, 2005, 08:11:27 AM »
must say, don't ya love those old 028's  :D great saws.  I still see them in the second hand shops for 100 or less.
Offline redpowerd
« Reply #15 on: May 28, 2005, 08:21:31 AM »
does the wizzard cover you with wood chips?
NO FARMERS -- NO FOOD
northern adirondak yankee farmer
Offline Quartlow
  • Amuture Sawer, master wood destroyer
« Reply #16 on: May 28, 2005, 08:56:18 AM »
YES!! And I'm here to tell you if it grabs a rock you better be wearing a pair of chaps, learned that lesson the hard way. I personaly used mine on two really bad logs and its sitting on a shelf now.
Since I don't have a debarker on the mill my new approach is to use a cheap lennox blade and just skim the log and keep rolling it till its cleaned off, switch back to a good blade and go to making boards.
Breezewood 24 inch mill
Have a wooderful day!!
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #17 on: May 28, 2005, 08:58:57 AM »
   I bought one in 94  and have been using it since ,  the knives to get dull on thick caked mud that is in pine bark ... but only takes but a few minutes to change the knives , I tried the carbide blades on it ... dont go there ... they break easily ..  I have mine install on a 034  with a short bar like  stump_jumper has his ..  makes it comfortable ... well as comfortable as working with it gets ..I,ll get a pic of it and post it here later on today .
  Woodmills     those 028's where and stihl are a good saw .  ;D  We can get them new here , dont know if they will be or are as good as the old ones though .
  Quartlow ... is it for sale , mine has a lot of millage and will need to be replaced in the near futur ...
   Marcel
Offline Quartlow
« Reply #18 on: May 28, 2005, 09:07:58 AM »
I don't know, I try not to sell anything  :D :D every time I do I end up wishing I hadn't.
Offline isawlogs
« Reply #19 on: May 28, 2005, 09:14:44 AM »
      I thought I was the only one doing that ...  ;)  ;D
   Marcel
Mr. Wizard
Started by Tom on General Board
Last post June 16, 2007, 07:49:06 AM
by Quartlow
Log wizard
Started by The Log Eater on Sawmills and Milling
Last post March 11, 2016, 07:50:23 PM
by Magicman
log wizard - blah
Started by Engineer on General Board
Last post December 04, 2018, 06:37:15 PM
by Russ
Looking at a Wood Wizard
Started by stonecold on Sawmills and Milling
Last post February 26, 2016, 09:12:48 AM
by RIBota
