Tally-I/O
Author Topic: different chains for soft/hardwood?  (Read 2243 times)
Offline J Beyer
  • If there were no trees, we would not be board.
« on: July 05, 2002, 08:19:04 AM »
In a previous post a person mentioned that they use a different style/cut on the chain teeth for soft/hardwood.  Is there a difference in plate angle that makes it work differently in soft/hardwood?  I know that when making ripping chain it makes a difference.
"The other Jeff B"
"From my cold, dead, hands you dirty Liberals"
Offline Bro. Noble
Re: different chains for soft/hardwood?
« Reply #1 on: July 05, 2002, 10:21:09 AM »
Jeff,
I've never heard of different chains for hard and soft wood.
You can file your drags lower with softwoods allowing you to cut faster.
Your elevator story on another thread reminded me of my cousin Jim.
We were on a crowded elevator on our way to visit our grandmother in the hospital.  Jim leaned over to me and whispered (loud enough so that the most hearing impared could have heard)  "Dr. are you sure your sober enough to operate?"  I was glad when the elevator doors finally opened.
Noble
Offline J Beyer
« Reply #2 on: July 05, 2002, 12:19:03 PM »
That could have been what I was thinking of.  If I remember correctly, isn't the softwood depth about .005 more than hardwood?
JB
Offline Bro. Noble
« Reply #3 on: July 05, 2002, 02:29:37 PM »
Jeff,
Thats probably right,  Just a little difference in height makes a lot of difference sawing.  The gage we use is called a file-o-plate if i remember correctly.  It is made to check cutteredge angle, tooth length as well as other things.  The only thing I ever use it for is to file drags.  It has two little holes (A&B) you stick the drag through one of the holes and file off whatever sticks through.  Use A for hardwoods and B for softwoods.  Since the plate sets at an angle between the base of one tooth and the cutting edge of the tooth that you are fileing the drag,  the drag is filed for that individual tooth.  That way each tooth on the chain takes off the same thickness of wood.  Makes it cut smoother and straighter.
Didn't think I could make an entire post without being silly did you?  Well, I guess this shows just how right you were!
Noble
Offline Kevin
« Reply #4 on: July 05, 2002, 06:50:42 PM »
A 10o side plate hook will help when cutting hardwood.
Offline woodman
  • I love cutting lumber on my wood mizer
    • Jim Cripanuk's Portable Saw Mill
« Reply #5 on: July 05, 2002, 10:50:28 PM »
  I file the drages way down for pine  the blade grabes and cuts very fast . But i just trim at the mill i do not cut down trees just mill them.
Jim Cripanuk
Bars & Chains for milling Hard and soft woods.
Started by dadkins on Chainsaws
Last post April 02, 2018, 12:22:24 PM
by mad murdock
Race Chains versus Working Chains
Started by Philbert on Chainsaws
Last post November 13, 2013, 10:50:35 PM
by Andyshine77
Pro chains and low kick back chains!
Started by KPSTIHLSAW on Chainsaws
Last post February 25, 2010, 12:32:34 PM
by HolmenTree
smiley
Soft Pretzels
Started by SwampDonkey on FOOD! FOOD! FOOD!
Last post February 17, 2008, 09:25:06 AM
by Patty
