Author Topic: Emerald Ash Borer  (Read 8626 times)
Online Ron Scott
Emerald Ash Borer
« on: July 31, 2002, 10:41:56 AM »
A new, exotic pest of ash (Fraxinus spp.) was recently discovered in southeastern Michigan. This Asian beetle belongs to the same family as the bronze birch borer and two-lined chestneu borer, Bupresidae. It's called the Emerald Ash Borer.
Extensive ash decline and mortality is occuring in Wayne, Macomb, Livingston, Oakland, St. Clair and Washtenaw Counties in southeast Michigan. Both ornamental and natural stands of white, black and green ash are affected.
In response, state agriculture officials have issued a quarantine on all ash trees and timber products in the affected counties to help prevent and control the spread of this pest. Under this quarantine, ash trees, branches, logs, and firewood may not be moved outside the affected area unless certified for movement by the Michigan Department of Agriculture (MDA).
A new pest alert describing the borer and it's damage; a map of the current known distribution of the borer; and a copy of the rews release used by the Michigan Department of Agriculture last week can be found at the following website:
http://www.na.fs.fed.us/spfo/eab/index.html
Please notify the Michigan DNR Forest Health Program, the Michigan Department of Agriculture or University Forest Entomologist if you find this insect or its damage on ash outside the known infected areas. It also occurs across the river from Detroit in Windsor, Ontario.
Tollfree Hotline: 1-866-325-0023
~Ron
Offline Ron Wenrich
Re: Emerald Ash Borer
« Reply #1 on: July 31, 2002, 07:00:34 PM »
If it's Asian, then it probably came in on pallets from China.  This is the second major pest to come in from Asia in the past 5 years.
When are we going to wise up and have them treat their pallets like Europe is doing to ours?  It really makes sense, although it is more expensive.
Offline CHARLIE
  • Don't wait 'til both feet are in hot water before you decide to put your best foot forward.
    • Coulee Region Woodturners
« Reply #2 on: July 31, 2002, 08:32:09 PM »
1. I don't think treating pallets is more expensive if you include the cost of trying to eradicate these foreign bugs and the loss of timber.
2. If they would build re-usable pallets, then the treated pallets could be used several times before they had to be scrapped. This would reduce the cost of treated pallets also.
Charlie
Offline woodmills1
  • the truth shall set you free
« Reply #3 on: August 01, 2002, 05:57:51 AM »
this interests me as we also have extensive ash decline here in southern NH.
Offline Ron Wenrich
« Reply #4 on: August 01, 2002, 04:03:50 PM »
Ash decline isn't due to borers.  One of the contributors is thought to be acid rain, thanks to Midwestern power plants.
Maybe the ash will go the way of the flowering dogwood.  It's been awhile since I've seen them as they were 30 years ago.
« Reply #5 on: August 01, 2002, 04:10:30 PM »
I'd like to say, "Come South", but, as pretty as the trees are, their aren't the trees that there were.  The woods used to be full of dogwood and a trip down any highway was like a walk in the garden.  I guess I've not noticed the decline as much as some people because it has been so slow.  If acid rain is the culprit then the whole country suffers.
Offline woodmills1
« Reply #6 on: August 01, 2002, 08:58:34 PM »
now up here in nh i miss the dogwood of my wva days and come to think of it i miss the sassafrass also. was so nice to pull the young root and taste it.
Offline whitepe
  • blue by day, orange by night, and green in between
« Reply #7 on: August 18, 2002, 01:49:20 AM »
Folks,
I don't know what's causing it but all of the
"wild" ash trees in the small wooded gully
behind my back yard all died off last spring.
About 15-20 trees.
By wild I mean that they were not planted.
I have four that were planted in my back yard
from nursery stock in 1977 that are fine.
Most of the trees that died were 6-8 inches in diameter
but a few were 12-15 inches. I noticed it
when they didn't leaf out in the spring.
I also had several dozen out of about 150 planted pine trees that died off over the last 3-4 years. I think that
pine bark beetles got them but again I am not sure.
I cut all of the dead ones down and burned them.
Back in 1988-1989, these same pine trees were losing
all of their needles. A closer inspection revealed
thousands of worms all over the trees. I took a couple
to the local lawn and garden nursery and they
said that they were saw fly larva.  I bought a quart or
two of evergreen spray and about three 75 foot sections
of garden hose and sprayed all of the trees.
The larva all dropped off the trees and immediately died.
blue by day, orange by night and green in between
Offline swampwhiteoak
« Reply #8 on: March 03, 2003, 03:50:16 PM »
An isolated pocket of Emerald Ash Borer was just confirmed in Lucas County Ohio.  I had the opportunity to look at the site, this thing is not pretty and is going to be very tough to survey for.  Has anyone had the chance to take a look at the damage in Michigan?
News Release and a few pictures
http://www.state.oh.us/agr/PLNT-eabindex.html
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #9 on: March 04, 2003, 05:21:17 PM »
Here are some pics that Swamp took that he will have comments for. Some nasty results from this pest. We may lose a lot of our Ash. They are talking possibly on the scale of the dutch elm.
« Reply #10 on: March 06, 2003, 06:41:07 AM »
Thanks for posting the pictures Jeff.
Pic #1 - You can see gallery activity and the characteristic "D" shaped exit hole.
Pic #2 - Like #1, this is with the bark removed, this is the only known borer that has this type of activity on ash.
Pic #3 - Unlike the USDA fact sheet, where the larvae look lime green, it's actually a milky white.  The larvae of Agrilus species tend to get into a U-shape prior to pupation.
Pic #4 - This is what the bark of the trees looked like due to woodpecker activity.  These things must be tasty because the trees were absolutely covered with woodpecker holes.
It's unknown how the insect jumped from where it was in Michigan to Ohio.  It almost has to have been moved by a human, probably in firewood.  Respect quarantines!
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #11 on: March 06, 2003, 10:11:58 PM »
That's scary :o :( :'(
Online Jeff
  • Fearless Leader
« Reply #12 on: March 07, 2003, 07:31:47 AM »
If you have ash you should be afraid. Very Afraid. From what I am hearing is that they may try to actually eliminate the ash species from infected areas to try to stop the spread. I doubt if they can contain this. Looking at swamps photos, its pretty apparent that they can't.
Offline redpowerd
« Reply #13 on: March 07, 2003, 08:08:07 AM »
that is preeeety freaky! i hope it dont come up north, are them the only two states with the problem? id like to see some pics of what its done overseas. im a gunna shoe some snow this afternoon an keep my eyes peeled. they look like they would make some pretty cabin logs.
NO FARMERS -- NO FOOD
northern adirondak yankee farmer
« Reply #14 on: March 07, 2003, 08:53:40 AM »
The borer is native to Asia, since it has evolved with the ash over there it isn't a huge problem. Actually when they originally discovered this insect, no one could figure out what it was.  It got bounced around to different labs, I think someone in Britian eventually came back with the answer.
The USFS people that have been working on this is Michigan came down to Ohio to help identify it.  I got a chance to pick some of their brains about it.  They estimated this damage (in Ohio) started probably 3 yrs ago.  The borer will start near where the crown forks, usually 4-6" material and then move down the tree.  What that says to me is that it is going to be very tough to survey for, since climbing 50 feet up every ash tree just isn't going to happen.  The Ohio Dept. of Agriculture is coming up with a plan to deal with our infestation.  As I understand it, the original plan in Michigan was to create a 3 mile wide "fire break" around infested areas where every ash tree would be taken down.  Hopefully it isn't too late for that plan to work out.  Don't know about Michigan, but ash is common in nearly every forest type in Ohio.  I'm probably paranoid, but I'm afraid that if this insect isn't controlled quick, ash will end up being like elm, still common, but never like it used to be.
Offline Kevin_H.
  • my two boys
« Reply #15 on: March 09, 2003, 07:06:04 PM »
I had a sawing customer call today, seems he has some ash trees he needs cut up. He told me that all the tops have fallen out of them.
When he cut them down he found black beetles in them, Does not sound like the ash borer, I hope to get some pics later this month when I saw them up.
Got my WM lt40g24, Setworks and debarker in oct. '97, been sawing part time ever since, Moving logs with a bobcat.
Online Ron Scott
« Reply #16 on: March 11, 2003, 02:53:42 PM »
Adults are dark metallic green (Emerald) in color, measuring approximately 1/2 inch long and 1/16 inch wide, and are present from May until late june.
Larvae are creamy white color and can be found under the bark of affected trees as noted in Swamp's photos above.
It infects all ash trees in Michigan, white, black, and green. Infested trees exhibit top-down dieback.
Report any suspected infestations to the Emerald Ash Borer Hot Line at 866-325-0023
~Ron
Offline Corley5
    • Whittaker Farms
« Reply #17 on: March 11, 2003, 09:26:21 PM »
I assume the adult beetles can fly.  How far can they fly seeking other trees to infect?  I've got a few nice ash around the place and some real nice regen in a spot.  I'd really hate to lose any of it.  Then if the Beech bug comes along there they go and if the Asian Long-Horned Beetle shows up... >:( :( :'(  Are we going to have any native species left or are we going to have to reforest with Asian varieties? ::)
Online Ron Scott
« Reply #18 on: March 12, 2003, 02:07:02 PM »
Yes, the emerald ash borer is a good flier, but human activities are the primary cause of long distance spread. This includes moving infested trees, logs, and firewood.
Transporting ash firewood from a southern Michigan woodlot to a northern Michigan deer camp is not a good idea so hopefully the quarantine is respected.
It seems that there is always somethin "new" attacking our trees.
~Ron
Online Jeff
  • Fearless Leader
Emerald ash borer confirmed in MD
« Reply #19 on: September 08, 2003, 01:38:54 PM »
See press release:
http://www.mda.state.md.us/press/eabadv.htm
The pest reportedly came in on infested nursery stock that traveled from Michigan to Tennessee to Maryland via the trade.  A State inspector conducting a routine inspection for fire ants made the intial discovery, which was later confirmed by appropriate agencies.  Most units were destroyed, but 20 infested trees have been sold and are at unknown locations in the landscape.  MDA is working with nurserymen to research records and determine locations of buyers of affected stock.  Surveys are planned.  Ash is not a significant component of forests in the vicinity of the nursery, so surveys will focus on urban areas where ash is present at that location.
Emerald Ash Borer
Started by Chuck White on Ask The Forester
Last post May 26, 2009, 10:20:56 AM
by wesdor
emerald ash borer
Started by sprucebunny on Forest Education
Last post April 09, 2019, 01:04:04 PM
by Woodpecker52
Emerald Ash Borer
Started by ruckus on Ask The Forester
Last post April 30, 2013, 07:35:40 PM
by samandothers
Emerald Ash Borer
Started by sharp-shod on Forestry and Logging
Last post October 13, 2010, 11:57:17 PM
by Okrafarmer
