Author Topic: Sawmill Identification.  (Read 6004 times)
Offline Tremel
  • Always looking for old oilfield relics
    • Tremel Family Homepage
« on: October 26, 2005, 02:28:06 PM »
Hi,
I have aquired an old circular sawmill and I'm unsure of the make.  I know what a Frick, Farquar and Belsaw look like, but this is neither.  Is there a website out there I can use to ID this mill?  It's an early flatbelt drive with babbit bearings.
--Bill
Bill Tremel
Claysville, PA
Collector of Antique engines, Trucks, tractors and hobby farmer.
Offline ronwood
  • Enjoy Making Sawdust !!
Re: Sawmill Identification.
« Reply #1 on: October 26, 2005, 02:31:55 PM »
Tremel,
If you have an pics to post you might be able to have it identified by one of the members. Myself I not to good at identifing circle mills.
Ron
Sawing part time mostly urban logs -St. Louis/Warrenton, Mo.
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #2 on: October 26, 2005, 03:50:55 PM »
This is THEE sawmill and sawyer webstie so I would say if yer going to get it identified it would be here.  A few photos should do the trick and or perhaps some discriptions of the unique features of the mill
Offline Ron Wenrich
  • Forester
« Reply #3 on: October 26, 2005, 05:57:51 PM »
Look at the parts number.  Usually there is a number on the dog ratchets or other parts.  There is a letter that starts out before the number.  All the parts will start with that letter.  That can lead you to the mfg.
Offline Sawyerfortyish
  • Bigger they are the more mess they make
« Reply #4 on: October 26, 2005, 08:20:15 PM »
Sometimes just knowing where your located can help. I know mills get moved but in my area most of the mills were made by the American sawmill company. Frick and farquar were popular in PA. Go in up state NY and Ireland mills were popular jump over into Vt and your in Lane sawmill country. Put some pictures on here and you'll get the answer your looking for.
Offline Tremel
« Reply #5 on: October 27, 2005, 10:07:00 AM »
I'm having a little trouble uploading the pics.  I had to drop them down to 30KB each, so the quality is not very good.  I'm trying to post these pictures someplace else.
I'm located in SW PA.  The mill was at my friends house, about an hour from me, in Ohio.  (Ohio Valley).  I have since moved the mill to my house.
I hope this works
Bill Tremel
Claysville, PA
Offline Tremel
« Reply #6 on: October 27, 2005, 10:24:02 AM »
Try this...
EDITED
NOTE FROM JEFF
I took your 100k files and reduced them to less then 20, and replaced them. The ones above now are as clear now as the ones that were in this post.  Try using the jpeg optimizer you can download free from www.xat.com.  Make your photos 350 or 400 pixles wide as a first step, then optomize them with the JPG compression tool to keep enough quality.  :)
Bill Tremel
Claysville, PA
« Reply #7 on: October 27, 2005, 10:26:27 AM »
Bill,
Do you push the handle to gig back and pull it to saw?
I ask because the circle millers on the board have made a case of it being safest one way or the other.
Offline Tremel
« Reply #8 on: October 27, 2005, 10:47:17 AM »
I can't remember.  It's opposite of a Frick and BelSaw.  I plan on changing this by removing the gear drive (that drives the carrige cable) and replacing it with a chain drive.  Sawdust gets into the gears and jams.  I'm also going to move the handle out and back when I get everything enclosed.
I have alot of work to do on this mill.  I want to make it safer as well.
Bill Tremel
Claysville, PA
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #9 on: October 27, 2005, 12:56:27 PM »
The stick should advance the carriage when it's pulled back and reverse it when it's pushed ahead.  It's a safety feature so if the sawyer gets caught on a knot etc. as the log passes by on the way to the saw when he, the sawyer, is pushed against the stick the carriage will go back rather then dragging him into the saw even faster.
« Reply #10 on: October 27, 2005, 12:59:28 PM »
On the head block where the dog slides up and down is there a second handle that forces the dog deeper in the log when pushed. That looks like my old American mill. I can't tell the pictures are dark but the belt tightener on the husk is the same and the gear on the carriage that backs up the headblocks looks the same. Maybe some closer pictures of the carrige and husk would help. When you said sawdust jams the bull gear that drives the cable that was always a problem I had to. Crawl under the husk and clean out around that gear(I hated that).
Offline Ron Wenrich
  • Forester
« Reply #11 on: October 27, 2005, 05:35:48 PM »
If your carriage is running backwards (going forward when you push), then your cable is on backwards.
I bet if its a Frick, Frickman will know.    ;)
Offline Frickman
  • Ouch, that hurt!
« Reply #12 on: October 30, 2005, 02:28:12 PM »
Looks like a Frick to me, either a 0 or 00. If it's a 0, it will have a 36" opening on the headblocks. A 00 will have a 33" opening. It is always possible that it could be a combination of different makes too. I've seen one brand of carriage mated to another brand of husk before.
If you're not broke down once in a while, you're not working hard enough
I'm not a hillbilly. I'm an "Appalachian American"
Retired  Conventional hand-felling logging operation with cable skidder and forwarder, Frick 01 handset sawmill
Pretend farmer when I have the time
Offline Tremel
« Reply #13 on: October 31, 2005, 11:22:07 AM »
I moved the mill this weekend and I'm getting ready to re-assemble.  Here's a closeup of the husk and carrige.
http://www.nationalpike.com/mill/mill4.jpg
http://www.nationalpike.com/mill/mill5.jpg
Bill Tremel
Claysville, PA
Offline Ron Wenrich
  • Forester
« Reply #14 on: October 31, 2005, 05:29:06 PM »
It looks a little like the old Fahrquahr we used to have.  The dog handles weren't quite like that one though.  You could use Frick parts on most Fahrqs.  The setworks don't look quite like a Frick or a Meadows.  Didn't the Fricks have a guage on the headblocks to tell you where you were at?
Offline Buzz-sawyer
  • To see it is to saw it....
« Reply #15 on: October 31, 2005, 05:51:27 PM »
Godd to have ya here!
Have you put a mill together before?..........
Be carefull when putting the blade back on , not to over tighten and possibly spring the collars........
there a several little things like that that sure help prevent trouble ;D
    HEAR THAT BLADE SING!
Offline Frickman
  • Ouch, that hurt!
« Reply #16 on: October 31, 2005, 08:59:59 PM »
The setworks, if they're Frick, look like they're the real old ones, like 80 or 100 years old. When you recede the carriage by hand, does it recede when you push back? On some of the real, real old ones you pulled the headblocks forward, as you usually do, but when you twisted the handle to recede the headblocks went back when you pushed, not pulled.
The handles on the dogs look like they came off something else, or somebody just welded on some balls. The dogs themselves come out the bottom of the casting. The newer ones come out the top. Maybe Frick made some like this, or maybe they're Farquar dog assemblies.
Most of the mills did have a scale on the first headblock, but not all. Larger mills frequently have dial gauges that run off the setshaft, similar to an automatic mill, and do not need the horizontal scale. This size of mill would probably have the horizontal scale. I don't see though any holes where a scale was mounted.
The carriage frame is built a little different than any Frick mill I've seen. It could have been rebuilt by someone though when an old, wood frame wore out. The trucks are mounted a little different too.
You might have a Frick, or Farquar, or something else, it's hard to tell from the pictures. Whatever it is, if it saws good lumber, it's a good mill.  :)
Offline Tremel
Re: Sawmill Identification. (Identified!!!)
« Reply #17 on: December 05, 2005, 12:57:02 PM »
I figured out what mill I have.   8)  It's an American #1 variable BELT drive mill built in the mid 1920's.
The winter weather set in and I haven't made much progress on getting it back up and running.  I'm waiting for an indian summer.
Bill Tremel
Claysville, PA
Offline D._Frederick
« Reply #18 on: December 05, 2005, 05:47:27 PM »
Tremel,
The "splitter" looks like the one that was on our No. 2 American.
I would suggest that you drill a hole through your husk timbers were they are splitting and put a bolt and nut to stop the splitting.
sawmill identification
Started by ga.player on Sawmills and Milling
Last post June 16, 2007, 04:08:36 PM
by WDH
Circular sawmill identification and value?
Started by Case1030 on Sawmills and Milling
Last post May 15, 2019, 01:15:12 PM
by jimparamedic
Oak Identification
Started by KK on Ask The Forester
Last post September 28, 2010, 11:07:50 AM
by WDH
Elm identification
Started by swampsawyer914 on Tree, Plant and Wood I.D.
Last post July 05, 2019, 12:02:21 AM
by Bandmill Bandit
