Author Topic: Palm sander, PSA stick problem  (Read 5540 times)
Offline ElectricAl
  • 1993 LT40HDE15 2012 LT50HDE25
« on: November 04, 2005, 08:55:21 PM »
We have 4 Porter Cable 334 Palm sanders that use PSA sandpaper.
The problem is the PSA sandpaper won't stick very well or not at all.
I have tried new pads on 2 and they worked fine for the first couple of papers, but now are worthless.
Any ideas on how to safely clean the pads, they are not worn out.
Linda and I custom saw NHLA Grade Lumber, do retail sales, and provide Kiln Services full time.
Re: Palm sander, PSA stick problem
« Reply #1 on: November 04, 2005, 09:03:57 PM »
Al,
Most of the folks that I know who use those sanders, use Hook and loop.  The PSA is notorious for sticking only one time.   If the problem is that you can't re-use a sanding disc then it is a common problem.  I'll search for someone who can verify what I have said and maybe could offer a solution.
Offline sprucebunny
  • Gender: Female
« Reply #2 on: November 04, 2005, 09:11:14 PM »
I use the hook and loop one but have used other sanders that you sprayed the adhesive on. Available at my auto parts store.
Spraying something on might make things work better or it might just make a sticky mess :D
Offline chet
« Reply #3 on: November 04, 2005, 09:13:08 PM »
I bought a sheet of the hook material and used disc adhesive to attach it to my PSA sander pads. You can buy the hook pads for your sander, but what I did was way cheeper.
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
Offline Tom_Averwater
  • Semi- retired Carpenter
« Reply #4 on: November 04, 2005, 09:42:40 PM »
I've got a Porter Cable sander also. I clean the pad with paint thinner when it gets dirty with dust and glue .
He who dies with the most toys wins .
Offline woodbowl
  • Making dough bowls, is a lot of work, but fun.
    • Have Sawmill, Will Travel
« Reply #5 on: November 04, 2005, 09:47:00 PM »
I got tired of cleaning the pad also so I went to Lowes and got a hook and loop kit to glue on to the existing pad.
Full time custom sawing at the customers site since 1995.  WoodMizer LT40 Super Hyd.
Online Larry
« Reply #6 on: November 04, 2005, 11:22:13 PM »
Al, I assume your putting a different grit on each sander and leaving the disc on until itís worn out.  A little lacquer thinner to clean the pads helps.  If your trying to change before the disc is wore out hook and loop would be better.  I also use Klingspor sandpaper...if ya ever have a problem just call them and they will make it right.
Offline Ironwood
    • http://www.branchandburl.com
« Reply #7 on: November 06, 2005, 04:11:21 PM »
I use numerous PSA pads on numerous sanders. Reuse of the paper is limited to using it by hand, as the adhesive is one shot. Usually I run the paper out until shot then pitch and replace. You should heat up the adhesive by using the sander and then peel it off. I do clean the pad on occasion with thinner or spirits. Don't try to reuse them it is not worth it. Quality of pads is critical, I like Carborundum brand. They are not cheap but last and cut quick. Time is money. If you are a hobbist and need to freaquently switch grits then the hook and loop are for you as stated.
                                   Reid
Offline Joe W
« Reply #8 on: November 06, 2005, 04:32:46 PM »
I use spray disk adhesive made by 3m.It is made for plain sandpaper,but I've used it on the psa disks as well.Should be able get it at any autobody supply store.
Offline ElectricAl
« Reply #9 on: November 06, 2005, 05:04:49 PM »
Thanks for the replies  ;)
Each sander has a different grit, and we use it until it flys off :-X
Once the paper is off, then it gets folded in1/2 and set by the lathe ;D
I cleaned 2 sanders with mineral spirits last night, but won't get a chance to use them until next Sunday ::)
I have tried a couple of Hook & Loop sanders and it appeared to not sand flat.
After sanding a top it felt wavy. I thought the loops had too much give.
Offline annia
  • Gender: Female
« Reply #10 on: January 04, 2018, 04:30:19 AM »
If your sandpaper is not sticking to your sander pad first check the sandpaper and sander pad for debris or moisture buildup.If there's dust take an compressor to the surface if there's wetness let it dry.
Annia Palmer
Offline 21incher
« Reply #11 on: January 04, 2018, 07:04:21 AM »
I have been using the psa paper for years and have the opposite problem where it sticks so good the stick surface on the sanding pad tears off. I only use Porter Cable and norton paper and always keep it sealed in rubbermade containers with dessicant packs. Humidity can affect the glue. As mentioned above I only use it once on the sander and then it goes in a box for hand sanding. I find the low cost harbor freight type paper will not stick good and then the heat from sanding makes it release like you are experiencing.  :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
help with wiring problem on wide belt sander
Started by Kelvin on Drying and Processing
Last post January 26, 2010, 10:05:28 AM
by Den Socling
question
problem with my delta belt/disk sander
Started by jueston on General Woodworking
Last post August 14, 2012, 11:09:50 PM
by 1woodguy
Wide belt sander vs drum sander
Started by oakiemac on Drying and Processing
Last post May 23, 2011, 10:10:31 PM
by oakiemac
Flatmaster Drum Sander, anyone have any experience this sander?
Started by Trahlin on General Woodworking
Last post December 06, 2015, 05:41:56 AM
by Kbeitz
