Baltic Abrasives Technologies
Author Topic: To set before or after sharpening  (Read 5204 times)
Offline GF
Re: To set before or after sharpening
« Reply #20 on: November 16, 2005, 10:30:03 AM »
Stephen,
     I also started to think about when you set and then sharpen and how this could cause not very smooth cuts.  The blade itself has different levelso of steel tension in them, I found this out by setting the teeth and some requireing additional pressure to set.  Now if this is the case when setting the tooth they all may not actually bend at the same exact spot it could be higher or lower.  Then when you sharpen even though you take off the same amount at each toot depending on where the tooth was actually bent into its set position could cause the cut to not be smooth.
Chain sharpening kit or automatic sharpening
Started by NovaSS on Chainsaws
Last post November 22, 2013, 02:29:18 PM
by thecfarm
Slick sharpening jig, for sharpening slicks.
Started by Dave Shepard on Timber Framing/Log construction
Last post August 21, 2017, 11:15:58 PM
by Andries
Sharpening at -2F
Started by Peter Drouin on Sawmills and Milling
Last post December 30, 2017, 07:13:25 AM
by Peter Drouin
Sharpening ?
Started by edsaws on Sawmills and Milling
Last post November 20, 2004, 10:18:24 AM
by Gilman
