measuring question
Started by Quebecnewf, November 15, 2005, 07:04:27 AM
Quebecnewf
If my permit to cut says 1000 cubic meters does this mean that I can cut enough logs to make 822,000 board ft of lumber. I am figuring a cubic meter is the same as 411 board ft
Any thoughts
for 8 ft softwood only
1 M^3 = 164 bft
1000 M^3= 164,000 bft ~ 328 cords
Quebecnewf
if a cubic meter is about 39x39x39=59319 cub inches/by 144 cubic inches( a board ft)= 412 brd ft. Where am I going wrong
Something about the recovery of square edged material (a board foot) from a round log. Not a 1:1 ratio.  ::)
Exactly  8)  ;)
And to add to the confusion  ;D
1000 M^3 Stacked = 84,000 bft ~ 276 cords
Stephen
There was an recent post similar to this. Try this link
https://forestryforum.com/board/index.php?topic=14393.msg203006#msg203006
where 1 Mbfm X 5.663 = 1m cubed
If my math was correct, 1000 cubic metres divided by 5.663 =177 thousand feet logs.
Stephen
1994 WoodMizer LT40G18. 69 acres mixed wood. 1952 ford tractor, Norse 290 winch, studed Norse ice chains. 45-66DT Fiat.
Quebecnewf
more questions
If I am allowed to cut 1000 cubic meters of logs per year how many board ft approx would this give me sawing with a bandmill and doing a good job of sawing. Which I think I do???????
I suppose that would have a lot to do with if they were 8" logs or 28" logs. Estimating volumes is just that, an estimation. For an estimation to be close you need to input as many of the variables as possible.
Stephen
I have more to say tonite than I have had in the past year.
Depending on log size and the scale used to determine that 5.663 cubes = 1000 Mbdft and that 1000 cubes = 177 Mbdft, you should average a 10-30% increase in scale using a band mill and taking light slabes.
Therefore maybe 210 Mbdft?
My self-educated guess!
Stephen
QuoteI have more to say tonite than I have had in the past year
COOL!  :D  Since yer in a gabbin mood, what da ya wanna talk about? We can always get back to the volumes thing when Quebecnewf  gets back :D
Quote from: Jeff B on November 15, 2005, 08:22:25 PM
:D :D :D :D I know it must be one of them nights  ::)
In all seriousness guys, the conversion differs not only by diameter of the log, but also the length (because of increasing taper with length). There were many samples measured at local mills here to get that conversion factor for 8 foot softwood (spruce-fir). Stephen's figures are for 8' hardwood and birch and are bang on with what we found here. Quebecnewf is going to be dealing mainly with spruce-fir, and probably some white birch or soft maple if I'm not mistaken.
Stephen
Just got back from a fire call.
Can we highjack the topic and talk about food? :D
Does that mean you was out roastin Marshmellows?
