Author Topic: Hydraulic feed  (Read 1463 times)
Offline wiam
Hydraulic feed
« on: November 16, 2005, 09:02:02 PM »
How much hydraulic motor would I need to pull the carraige on a bandsaw mill?
Will
Offline Vermonter
  • Best logs I'll probably ever saw-52" EWP
Re: Hydraulic feed
« Reply #1 on: November 16, 2005, 10:26:28 PM »
It depends on how fast you want it to move.
Have you tried pulling the sawhead with a spring balance to get an idea what kind of force is needed?
New homestead
Offline freddycougar
Re: Hydraulic feed
« Reply #2 on: November 18, 2005, 11:59:30 PM »
i am using hydraulic moters for the lift and feed fuctions... even small hyd moters deliver high torq..  more than enough to feed or lift a sawhead..
freddy
Offline D._Frederick
Re: Hydraulic feed
« Reply #3 on: November 19, 2005, 12:03:05 PM »
I would look for a hydraulic motor that has about 15 cubic inches displacement. The rpm will lower and the torque high with a motor of this size.
Re: Hydraulic feed
« Reply #4 on: November 20, 2005, 01:59:52 AM »
 depending on flow of the pump.. the pump and moter have to be matched up
freddy
Offline Lost Pines
Re: Hydraulic feed
« Reply #5 on: November 20, 2005, 09:32:47 PM »
Here is a link to some Hyd. Formulas
http://www.surpluscenter.com/Hydraulic.htm#RPV
It has a section on Cylinders, Pumps, Motors,
Leland
Hydraulic feed question?
Started by isassi on Sawmills and Milling
Last post January 14, 2006, 09:48:56 AM
by footer
LT 40 hydraulic power feed problem
Started by Mike_M on Sawmills and Milling
Last post June 25, 2010, 11:39:02 AM
by Mike_M
Just finished up my hydraulic feed today.
Started by hackberry jake on Sawmills and Milling
Last post April 04, 2014, 02:45:17 AM
by mad murdock
Pigroast Video Feed (Live feed if active, broad band required)
Last post August 03, 2009, 04:04:42 PM
by Reddog
