Author Topic: Quick Test  (Read 1812 times)
Offline Kevin
Quick Test
« on: September 18, 2002, 07:59:06 PM »
Lift the chain off the bar, if the bottom of the drive link clears the bar rails the chain is too loose.
You should be able to lift the drive link off the rails but if the bottom of the driver  clears the rails you should consider tensioning the chain slightly.
Now, everyone go try it and report back to Jeff.  :D
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: Quick Test
« Reply #1 on: September 18, 2002, 09:02:55 PM »
I don't have a chainsaw so I tried to lift my drive link out of my computor chair. My bottom did not clear the chair rails so I had Jeremy bring me a busch lite so I could begin the getting tight part.
Offline KiwiCharlie
  • Theres nuthin I like more than an UGLY log.......
Re: Quick Test
« Reply #2 on: September 18, 2002, 10:24:09 PM »
G'day Kevin,
Do I get a prize for being able to get my whole hand through the gap?? ??? :D :D
Guess not.
Good tip but, on a serious note.
Cheers
Charlie.
Walk tall and carry a big Stihl.
Offline Kevin
Re: Quick Test
« Reply #3 on: September 19, 2002, 05:19:50 AM »
Charlie, if you have your hand between Jeff and his chair you`re asking for trouble.  ;D
Offline LeeB
Re: Quick Test
« Reply #4 on: September 19, 2002, 07:17:15 AM »
and don't forget the rakers when sharpening. kept wondering why I couldn't get my chain sharp. had to take about a 32nd off the rakers. cuts like crazy now. LeeB ::)
Smoke Test - Pass, Functional Test - Pass!
Started by warren46 on Sawmills and Milling
Last post December 08, 2013, 10:58:59 AM
by samandothers
I need a quick fix
Started by dail_h on Sawmills and Milling
Last post September 24, 2004, 04:37:15 PM
by dail_h
A quick thank you!
Started by bo99 on Drying and Processing
Last post October 22, 2014, 06:12:52 AM
by red oaks lumber
Quick Fix
Started by Magicman on Sawmills and Milling
Last post March 24, 2015, 08:53:46 AM
by Magicman
