Author Topic: Gas Mixture Uses  (Read 1634 times)
Offline catvet
Gas Mixture Uses
« on: November 23, 2005, 09:55:00 PM »
So I bought, and mixed, too much gas for my stihl saw.  Does anyone know if this mixture could be used in other equipment (other than two cycle engines)?  It's a 1:50 mix.  I was wondering if I could add it my ATV or some other use before it goes stale.  I'm pretty much done with sawing for the winter.  I actually have most of next year's firewood supply cut and split.
Catvet
Northern Vermont
Offline beenthere
Re: Gas Mixture Uses
« Reply #1 on: November 23, 2005, 10:02:21 PM »
Next years?  I'm working to get the following year after next year split. I prefer it to dry at least 2 years, and hopefully 3 under cover. But that is just my hang-up.  :)  I think I have more than enough or this year and next, but as long as I enjoy making it, and have pallets to stack the split wood onto, I'll keep cuttin and splittin.
How much 'extra' gas do you have?
Offline Max sawdust
  • If it's got to do with making sawdust; count me in!
    • truetimbers.com
« Reply #2 on: November 23, 2005, 10:23:48 PM »
Hey beenthere,
You can come and split some of mine ;D  I have 100 cords in 100 inch lenght and still burning green wood this winter ::)
Since the main living level is only heated with wood the wife gets mad when she has to start a fire when I am gone :(  Too much birch bark required :o
No time for splitting with all that felling and milling that needs t
o be done.
Just kidding...I am with you on never having enough dry wood.
max
Catvet howmuch do you have premixed ???  No boat or snowmobile ???
Sounds like a good excuse to buy a boat or snomobile ;D  or some other cool two cycle toy.
True Timbers
Cedar Products-Log & Timber Frame Building-Milling-Positive Impact Forestscaping-Cut to Order Lumber
Offline Dale Hatfield
  • A plan is a start to a great ending
« Reply #3 on: November 23, 2005, 11:42:02 PM »
I only have mixed gas here on the farm.  The push mower / garden tractor/ 4 wheeler weedeater chainsaws all  get it. My trucks  even got it  in some as needed cases.   I dont really think its an issue . Their is very little oil in a 50:1 mix ratio.  It not like dumping in gallons of oil into the tank.  I  would just call it top end lube and dump it into a gas sucking monster.
Dale
Game Of Logging trainer,  College instructor of logging/Tree Care
Chainsaw Carver
Offline David_c
  • treat people the way you want to be treated.
« Reply #4 on: November 23, 2005, 11:42:59 PM »
If just a couple gallons dump it into car or truck. It won't hurt it. If more than a couple then do it a over next few tanks of fuel.
Offline mike_van
« Reply #5 on: November 24, 2005, 06:51:43 AM »
I wouldn't worry about 50/1 either - burn it in any engine -  now the old 16/1 you would want to spread out some -
I was the smartest 16 year old I ever knew.
Offline catvet
« Reply #6 on: November 24, 2005, 08:58:11 AM »
Thanks all.  We are only talking somewhere between 1 and 2 gal.  Thought I was doing more cutting than I did.
Catvet
Northern Vermont
fuel mixture
Started by woodsdog2015 on Chainsaws
Last post December 24, 2015, 12:45:06 PM
by HolmenTree
Jonsered 510 SP Gas/oil mixture
Started by bphelps38 on Chainsaws
Last post May 07, 2007, 09:04:18 PM
by Corley5
Gas mixture for the husqvarna 3120xp
Started by yarnammurt on Chainsaws
Last post February 28, 2013, 05:25:33 PM
by Al_Smith
Oil and gas mixture for Stihl machine
Started by alsayyed on Chainsaws
Last post March 01, 2006, 01:54:51 AM
by Alta
