KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Need help in fitting the small log mill on 30” bar  (Read 977 times)
Offline alsayyed
« on: November 25, 2005, 09:48:54 PM »
Hello everybody, I have purchased the small log mill from Granberg  international. I tried to fit the 30” stihl bar but it cuts but not straight I mean the small  log mill only have one screw from one . I should get the bigger so it holds the bar tightly. Know I do not want spend more money is there anyway that I could  fit that 30”  bar on the small log mill. I have another idea if you people will share with me I am thinking that make copy of the small log mill  that fit this type of 30” bar it could be done in the machine shop.
Online Furby
  • Blurb....
Re: Need help in fitting the small log mill on 30” bar
« Reply #1 on: November 25, 2005, 11:41:04 PM »
What direction does it not cut straight?
From one end of the bar to the other, as in you cut a wedge or tapered piece of wood?
If you have the Alaskan Small Log Mill, it is for bars under 20" long and could explain the problem if making a larger cut.
The Basic Alaskan Mills have an upright on each end to keep things even. It sounds like that is what you are talking about making?
Shouldn't be too hard to do for someone who knows how to work with metal.
Take a look at the Basic Alaskan Mills.
Offline WoodSmith
« Reply #2 on: November 27, 2005, 02:06:27 PM »
With the Small log mill there is nothing to guide then of the bar, so the longer the bar the more flex that there is. The small log mill will only except 20" max bar length.
http://www.toolcenter.com/sawmill/small.html
That extra 10" bar length is going to make a world of difference.
If you need to cut width's that are greater then what the 20" bar can cut you will have to go to using the Mark III mill.
Good Luck
hydraulic fitting
Started by rockwall on Forestry and Logging
Last post August 10, 2016, 08:28:57 AM
by Furu
Fitting joints
Started by Jim1611 on Timber Framing/Log construction
Last post December 14, 2014, 03:02:21 PM
by Dave Shepard
Test Fitting
Started by addicted on Timber Framing/Log construction
Last post October 31, 2015, 09:16:54 PM
by dean herring
Don't grease that fitting
Started by pnyberg on Sawmills and Milling
Last post July 16, 2011, 09:04:35 PM
by Don_Papenburg
