Author Topic: Husqvarna Parts  (Read 1697 times)
Offline Shawn
  • Perfect Sawdust, everytime!!!
    • Shawn's Woodworking Page
Husqvarna Parts
« on: December 10, 2005, 12:08:37 PM »
Where can I get the cover for the air inlet. Its cold here in Michigan. Also need a cant hook.
Change is part of the design process.
Admit nothing, Deny everything, Make counter-accusations
Offline Rocky_J
Re: Husqvarna Parts
« Reply #1 on: December 10, 2005, 02:31:27 PM »
The bestest cant hook in the entire world can be found just to my left.
<<<<<<  8) 8) 8)
Click on the pretty blue cant hook that says Logrite™ Tools.
I have no idea what part you need but I'd be willing to bet that Bailey's will be able to help you.
Offline Kevin
Re: Husqvarna Parts
« Reply #2 on: December 10, 2005, 04:51:58 PM »
Quote
It should be in the saw unless you lost it.
Check your owners manual .
Offline Rocky_J
Re: Husqvarna Parts
« Reply #3 on: December 10, 2005, 05:30:27 PM »
Also, shouldn't the hole be left open for cold weather use? It allows hot air from around the cylinder head to enter the air intake. Close the hole for summer use (here in Florida they stay closed year 'round unless you want your saw running hot).
Offline Kevin
Re: Husqvarna Parts
« Reply #4 on: December 10, 2005, 06:33:10 PM »
I found the reference...
Quote
Winter use
During winter time, powder snow and cold weather can cause
running problems, such as:
• Too low engine temperature.
• Icing on the air filter and carburettor.
Therefore some special measures are required:
• Partly reduce the air inlet of the starter and by doing that
increase the engine temperature.
• Preheat the intake air to the carburettor by removing the
special plug between the cylinder and the carburettor space.
The cylinder cover is made so it can be changed for running in
cold weather.
Offline husky girl
  • Gender: Female
  • Fire Dog
Re: Husqvarna Parts
« Reply #5 on: December 28, 2005, 05:00:04 PM »
We call Bailey's, ask for the saw shop, and get the part we need cheaper and faster than any saw shop locally.  (in regard to the "faster" we are in the same state)
Give a girl a saw and she'll change the world, or at least buck it up.
Husqvarna 41 saw parts
Started by Dana on Wanted
Last post February 22, 2012, 01:26:56 PM
by Dana
Husqvarna 362 365 372 371 parts
Started by Cut4fun on Wanted
Last post June 18, 2010, 06:46:56 PM
by Cut4fun
Husqvarna 550 XP Parts List
Started by HLSupply on Chainsaws
Last post October 01, 2016, 07:53:31 PM
by AdkStihl
How can you identify AM parts on a Husqvarna saw?
Started by weimedog on Chainsaws
Last post January 16, 2017, 03:23:38 PM
by weimedog
