Author Topic: 40:1 instead of 50:1?  (Read 91441 times)
Offline Todd
  • Utilizing eradicated Ash and urban hardwoods
« on: December 23, 2005, 08:08:11 AM »
I read on the topic of over-revving that some forum members were reccomending using a greater amount of oil in their pre-mix than the saw reccomends...using only 40:1 would let me keep just one can of mix around for my 2-stroke toys, but will my 394xp like getting the extra lube(50:1 reccomended), and what adjustments should I then make to the carb?  (or should I find someone who knows what the h*** they're doing to adjust it? ::)
Todd
Making somthing idiot-proof only leads to the creation of bigger idiots!
Offline clyde
Re: 40:1 instead of 50:1?
« Reply #1 on: December 23, 2005, 10:21:08 AM »
Your saw will be much better off at 40 to 1.  I think 50 to 1 is too little oil.  You really shouldn't have to tune it much with this change.  Theoreticaly it will be a little leaner on the fuel to oxygen ratio (less gas and more oil in a given volume) but this will be very slight.
Offline Rocky_J
« Reply #2 on: December 23, 2005, 11:11:22 AM »
Offline scottr
« Reply #3 on: December 23, 2005, 07:27:43 PM »
Todd , about a month ago a similar question on another forum revealed that Husqvarna recomends 3% oil for their saws that are over 80cc .
Offline Rockn H
  • long way to go
« Reply #4 on: December 24, 2005, 01:10:42 AM »
So, husqvarna recommends around a 33:1 mix?
Offline KarlP
« Reply #5 on: December 24, 2005, 06:17:29 AM »
I used their online form to ask them about this twice and got no response.  The third time I asked a simpler question to start with and followed up with what I really wanted to know.
Me: "What fuel to oil mix ratio to you recommend for the longest engine life of a Husqvarna 385xp used for chainsaw milling?"
Husq: "Thank you for contacting Husqvarna. The best fuel/oil mix will be the 50:1 ratio using quality 2 cycle oil that is designed for chainsaws, and use fresh fuel, 89-93 octane for best performance."
Me: "In that case I'm curious if you could tell me why one version of the US 385xp manuals (http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140238-95.pdf) as well as all of the manuals for New Zealand, Sweden, and many other countries recommend 33:1 for Husqvarna saws over 80cc? I assumed it was for longer engine life."
Husq: "The different ratio can be attributed to different fuel quality in the countries that you listed. The owners manuals for all Husqvarna products in the US call for a 50:1 fuel ratio."
That said, I myself use a 1 gallon Husqvarna mix in .85 gallons of Super Unleaded from the local Exxon station that has one hose for each grade in a new saw just incase the rumors of conventional oil leading to a better breakin are true.  After that I switch to 3oz of Mobil 1 racing per US gallon.  That both makes measurement easy and gives me around 42 2/3:1.
Offline Rocky_J
« Reply #6 on: December 24, 2005, 10:30:10 AM »
The other countries do not have the EPA. No manufacturer is legally allowed to recommend anything more than 50-1 mix in the USA. The other countries are not restricted by such legalities and they can actually recommend the mix that the saw was designed to use.
Offline scottr
« Reply #7 on: December 24, 2005, 12:27:40 PM »
 I just looked up the fuel to oil ratio for the new model PP4318AV that Stew was asking about . The ratio is 40:1 .
Offline Ianab
« Reply #8 on: December 24, 2005, 01:56:07 PM »
Interesting...
I picked up a new Dolmar 9600 last week.
The (International) user manual tell me to mix the oil 50:1. But the dealer AND the free ( bottled in NZ ) Dolmar oil bottle both say to mix 25:1 ???
I'll just carry on mixing 33:1 like I do with all my 2 strokes, none have died yet  :-\
Quote
I have been told that by various dealers in NZ too, and I can believe it as well  ::)
Offline StihlDoc
« Reply #9 on: December 25, 2005, 06:28:50 AM »
To clear up any misconceptions, the EPA does not mandate any mix ratio on two-strokes. The manufacturers tell the EPA what ratio and oil formulation is used when they give their emissions level data to the government. The ingredients in the oil and engine design are the determining factors in what a manufacturer recommends for a mix ratio.
Offline bitternut
« Reply #10 on: December 26, 2005, 08:54:51 PM »
So if I were to read between the lines the saw manufacturers stroke the test results by using a 50 to 1 mix but really design the saws to run best on a richer mixture. Since there is no EPA outside the US they are free to make recommendations of a richer mix.
Offline Joseph
  • I am new here!
« Reply #11 on: December 26, 2005, 09:35:57 PM »
Look like that, does it not?
I did look up the Operator's Manual{International Version] for my saw, a 395XP.
I will be running my saw on 33:1{3%] mix, per there International Operators Manual.
You can see a copy here;
http://weborder.husqvarna.com/order_static/doc/HOEN/HOEN2004/HOEN2004_1140256-26.pdf
And Yes they have the following on page 25, bottom right;
Mixing ratio
For engines up to 80 cc: 01:50 (2%)
For engines over 80 cc: 01:33 (3%)
Regards
Joseph
"Equipment Should Never be an Excuse for Poor Performance. If You are Going to be a Professional, You Get the Correct Equipment, then the Only Excuse is Your Ability to Perform." ★ ℠
Offline Todd
« Reply #12 on: December 27, 2005, 06:57:37 AM »
I just wanted to thank everyone for their responses...I think I'll start mixing a little more oil into that premix and quit worrying about getting that "exact" mixture now that I hear others are running 40-33:1 in their saws.  Watching me trying to get EXACTLY a 50:1 mix would probably have been an amusing experience for most people here. (and no, before anyone asks, I don't have any pictures of that! ;))
Todd
Offline StihlDoc
« Reply #13 on: December 27, 2005, 10:33:01 PM »
The oil mix ratio has only a minimal effect on what the EPA regulates. Scavenging loss (unburned gasoline) is the big contributor. The 50:1 ratios are recommended because the modern two-stroke oils have better additives to prevent ring sticking and piston seizure than the oils used 20 years ago. The newer oils used at richer than ecommended ratios can lead to deposit build-up and eventual engine damage over the long term due to deposit build-up.
Offline sawguy21
« Reply #14 on: December 27, 2005, 10:51:30 PM »
I am with StihlDoc on this one. Running a richer mixture also leads to plugging the ports and spark arrestor. I have not seen any oil related problems at 50:1, I have run my Husky 345 at 100:1 on Opti-2 for the last 5 years. However, it is your saw and your nickel, if you feel better running heavier by all means go for it.
Offline JD_Kid
  • CAS shooter
« Reply #15 on: December 28, 2005, 01:14:36 PM »
Hi ya's
Ianab intresting what ya say about  ya new saw  my  109 is ment to be 40-1 my 120Si  is 25-1 and my PS 9010 40-1  or higher if useing "brand oil's"   i have run all these on 100 -1 race oils tho   i think a lot depends on oil spec than mix rates
catch ya
JD
I used to smoke camels but found them hard to light and kicked to much
Offline bwalker
« Reply #16 on: December 29, 2005, 06:16:02 PM »
Quote
With all due respect, i know this is the Stihl company line. Its complete BS. OIl technology has changed very little untill the last 5 or so years. Well after 50:1  ratios first begain to be reccomended. the OEMS went to the numercily higher ratios in order to reduce visible smoke with the mediocre quality oils they sell.
 I run all my saws at 32:1 and I would challenge you to see anymore smoke than stihl orange bottle oil at 50:1 In fact I will bet you my saw will smoke less. Further more deposit levels will be less.
Offline Tillaway
  • Funny looking tall guy.
« Reply #17 on: December 29, 2005, 07:17:48 PM »
If you ever have a chance to look through Stihl's engine failure diagnostic manual you will find that running a mixture too rich say 33:1 leads to excessive carbon build up and piston scoring on the exhaust port side and ring sticking as the carbon build up falls back in on the piston.  It is the equivelent of running too lean as far as engine failure.  Probably more common since most people are more comfortable running a rich mix since they feel better.  Most folks don't notice the reduced service life since they put very few hours on a saw so service life still appears to be good to them.
Outboard manufacturers have had to deal with this problem for years since the fuel / oil mixture is rated to protect at wide open throttle.  They rarely run WTO all day so trolling was extremely hard on them and the motors suffered greatly as well as pumped allot of unburned oil into the water.
Making Tillamook Bay safe for bait; one salmon at a time.
Offline sawguy21
« Reply #18 on: December 29, 2005, 07:38:52 PM »
Tillaway is absolutely correct. With all due respect to bwalker and others, oil technology has changed dramatically and so have engines. The old engines had wider tolerances so required more of the oil that was available at the time. They also ran at lower speeds and did not need the new super oils.
 A friend who is from the old school insisted on running his Johnson outboard on SAE30 at 16:1 just as he did in the fifties. I convinced him to use outboard motor oil because of hard starting and fouled plugs. He still refuses to go any leaner than 20:1 yet there is a white goop which is water and unburned oil in the exhaust port. The new concentrated oils simply will not burn clean when mixed too heavily.
Offline StihlDoc
« Reply #19 on: December 29, 2005, 09:10:03 PM »
With all due respect, i know this is the Stihl company line. Its complete BS. OIl technology has changed very little untill the last 5 or so years. Well after 50:1  ratios first begain to be reccomended. the OEMS went to the numercily higher ratios in order to reduce visible smoke with the mediocre quality oils they sell...
With all due respect, I have been around two-stroke engine and lubricant development for over 30 years and have not experienced the same observations you supplied. I would be interested to know where your information comes from or is it personal opinion?
