Miner Edger
Started by Rick Schmalzried, October 09, 2002, 09:19:57 PM
Rick Schmalzried
Well I finally got down and picked up the edger from my Brother in Law.  8) I am hoping that I am not getting in too deep on the necessary restoration. ::) But more on that later.  Anyway I felt like one of the 3 stooges trying to unload it from the trailer.
But after much sweating by myself and laughing by my wife I finally got the trailer pulled out from under the edger and the edger setting on some logs.
So now comes the real work that I need help from the forum.  This is a miner edger, built in Meridian Miss, who knows when.
The blade shaft spins freely but the output feed roller needs new bearings.
I have no experience pouring babbet so I am wondering what you would do to get this to spin.  Would I be better to cut the bearing support off and replace it with a pillow block???  If I can get this working, I will have a bunch of working making guards as I am NOT going to risk myself running this as it exists now :-* :-*
_
|_| .  _ |
| \ | |_ |<
Paul_H
Rick,
I think you have a pretty cool project on your hands.I would love to have one to play with.
Try this link   http://www.soule-miner.com/mineredger.htm
Look forward to more on your project as it progresses.
ADfields
Hi Rick
Well I would say dont waste your time with the babbet!   A pillow or a flange block is always the way to go on somthing you plan on working.   If I was rebilding it I would put all new pillow or a flange blocks on all the shafts first thing and be don with it, you would never need tinker with it after that!
It looks like you will have a blast with that thing, I know I would! :)
Andy
Bro. Noble
Rick,
Your edger looks about the same as ours.  Ours is a Corley.
If you are down this way sometime you can see how it operates and might get an idea for a guard.
Pouring babbit isn't too bad, just block the sides to contain the material and pour it in place, then use ink or carbon paper to identify high spots and scrape them off.  You may be able to buy new ones through the website Paul posted.
Noble
Fla._Deadheader
Hi guys. Just for the info, there is (was)? a magazine called Gas Engine Magazine, that is for collectors of old 1 cylinder Stationary,althought they were VERY portable, gas engines. Had water hoppers on top of the cylinder.
   Ennyhoo, there were ads in there where you could send your bearings off and have them re-poured. Then you could "fit" them, as Noble described. I had an old Fairbanks battery gen set in Arkansas, that I used for electricity, along with the 4000 watt windmill that I built. NO APL for us !! I re-poured the bearings myself. Not REALLY tough, but, a little tricky. Use the acy torch to "smoke" the shaft, so the Babbitt won't stick.  Harold
Paul_H
ADfields
WOW I have the same power hamer, 50 pound Little Giant!   Cool link but I put tapered wheel bearings in it when I got it in 1981.   I have not done forgeing in about 10 years now but hope to get it set in a shop this winter.
Andy
Paul_H
Andy,
What did you mainly make with it?
Bro. Noble
Andy,
I used to mess with antique engines.  I needed a valve made onetime and was refered to an old fellow that lived fairly close to me (at Noble Mo.).  I made an appointment to go there.  His machinery ( lathe, milling machine, tripp hammer, drill press) was all ancient and was driven through a line shaft powered by an old hit and miss engine.  He did machining, blacksmithing and gunsmithing.  He had about a dozen old engines lined up in a row.  He would walk by them and spin the wheels.  Each one started the first turn.  He had used the trip hammer to sharpen tons of plow shares when that was the way things were done.  I came up with a lot of reasons to go see him between that first visit and his passing.  If he charged me anything at all, it was always very little.  Each time he would say,  "There's two things a blacksmith will go to hell for----beating cold metal, and not charging enough".
Noble
ADfields
Paul
Well I made all kinds of stuff.   I got hooked when I went with a welder frind of mine to a blacksmithing club meeting (AABA) in phoenix and watched a smith make a patern welded steel (damaskus) knife blade.   On the farm I lerned welding befor I lerned to walk good and my granddad was a smith so we had all the tools but he pased on 2 years befor I was hached.   So I got hooked and about lost my wife over all the time I spent lerning it and still working for a liveing but it was my love for a number of years and I ran a shop on the side.   I made forged steel (iron) gates, fancey brackets for poste and beams, door pulls, and all kinds of custom forgings and never the same thing twice, just whatever people would want made from metal.   My clame to fame was a 999%fine silver horse shooe for Gorge Bush Sr.   I had become the guy that would take the hard things that other smiths did not want and thay would send them my way.   I had a photo of Gorge holding it all framed up with the invoice ($83 labor, used ther silver) but it burned with my house in Arizona May first 2001.   I am in the proses of seting up a shop for metel work on one end and wood on the other compleet with sprinkelers and a roll up door in between as a forge and sawdust dont mix well and the wife and I have a bad feer of fire now.
Noble
That forge smoke will get you hooked as bad as dope!   The shop I'm seting up will be a line shed but powered by a Ford 2.8 V6 not a hit and miss.   But if I had the hit and miss I would be runing it for the power.   The old smith you knew sounds like a fun sort to spend some time with.   I have knon a lot of that sort over the years but I think thay are all gone now.   The one I wish I could have knon is my Grandad as all who did know him say that I am just like him and his 3 childern gave me all his old tools and say thay belong with me working not rusting in ther sheds.   My Mom wont let me bring the anvil to Alaska till she's gone even thow it's mine, thinks that to far away from her or somthing.   Your old smith was right it is a sin to beat cold metal (makes it "work hardened" and week) and I never had the hart to charge for the real number of hours it took to do something, but I shure had lots of fun.
Andy
mitch
 I rebuilt an old 30 inch Tower Edger that had babbitt bearings. On the main saw mandrel I used 1 15/16 inch pillow block bearings and for the feed rolls I knocked out the babbitt and bored out bearing bronze stock as a replacement. Some images are at URL
http://shagbarkfarms.com/Edger
Meadows Mills bought out Miner. The URL is
http://www.meadowsmills.com/miner-edger.htm
mitch
 Lindsay Publications Inc.  at URL
     http://www.lindsaybks.com/
has a book No. 1524 entitled "How I Pour Babbitt Bearings" by Vince Gingery. He lists sources for needed supplies and uses as his example pouring babbitt for an old sawmill mandrel.
FeltzE
Don't pour new babbits, buy an insert from a local bearing company just need the dimensions and you can put an oil impregnated bushing in that, or new bearings if you are lucky they may have something with needle bearings that will do the trick
Good Luck
Eric
D._Frederick
Rick,
The problem you may run into is alignment. The machines with babbit bearing were mostly all cast iron. The feed and pressure rolls, and arbor were all aligned together and then the babbit was poured. If you loose this alignment, your edger may not cut straight. From the photo, it appears the cast part of the bearing  is broken and missing. It may be less work to brazes a piece of pipe to complete the bearing and then re-pore the bearing. Babbit is not that hard to work with, if you got a plumber friend, they may have the tools your need.
Andy, I've always had a hankering to try blacksmithing.  I have my great-great-grandaddy's anvil, a 110 pounder. It has more life in it than any I've ever tried. You have to stand to the side, or yer hammer will hit you in the face! :o  GG-Grandpa was a cooper, and made barrels for the cane syrup industry in Cairo, Ga.  The Cairo HS football team is still called "The Syrupmakers."
The anvil is known to be in the family since 1859, but may go back another generation or two.
ADfields
Hi DanG
Blacksmithing will get in your skin just as bad as sawmilling!   Your old anvil is a forged anvil with a carbon steel (tool steel) slab forgewelded (fused togather with heat, flux and a big hamer) to it's face, thay are no longer made!   The forged anvil will ring true and bounce your hammer back as hard as it hit the anvil if you miss the iron.   If you watch a smith working he will tap the iron 2 or 3 times then ring the anvil once (tap tap ring tap tap ring) that is so the heat that the hammer just picked up from the iron will go into the anvil and save the temper on the hammer, bet ya did not know that.   Forged anvils also will have a divet under the horn and under the heel that the tongs put in it as IT was forged, also one under the bottom and top but the top is covered by the carbon steel face.   Thay would put a charge of black powder in that bottom hole and "blow the anvil" up in the air on the 4th of July.   I have a bunch of anvils from very old to very new but my Grandad's anvil is the one I love the best, it's a USA made 1892 122 pounder.    Now all thay make is cast steel anvils and thay are not neer as good to work on.   Well I should stop runing on about anvils.     ::)
Andy
Bro. Noble
Andy,
I love that kind of stuff------tell us more------you didn't even get to the hardy hole.  And that round one, the pritchel isn't it?
Noble
ADfields
Yup the pritchel (if thats how you spell it) hole is for the pritchel to pass into when forging horse shooes.   Well it's just for drifting a hole with a small drift punch but for the most part all drifted holes were made with a pritchel witch is just a squre punch made with low carbon steel.   Back in the day of the blacksmith it was a lot of work to drill a hole and it made the iron week becous iron (unlike steel) has a grane in it just like wood.   So thay would take a heat on the iron and put it over the pritchel hole and drive the pritchel right thrue it to make a hole, this would shape the grane around the hole like a knot hole in wood grane.
The hardy hole holds tools cald hardys.   A hardy is all tools that are made to fit that hole so you can hold the iron in one hand and a hammer in the other and the anvil holds the 3rd tool for you.   Ther are hundreds of kinds of hardys like cold cutoffs witch are cold chisels that fit in that hole and hot cutoffs to cut hot iron and all kinds of other things.   Smiths would often make ther own hardys for just a one time use on some job and toss it in the back of the shop so if thay ever needed it agen thay would have it, this is why I often find old hardys that I have no clue what thay were for.
There is one other part to the good old blacksmiths anvil not meny people know what it's for and thats the chisel plate.   I talked about the steel face thay weld on it and if you look you will see it dont go all the way to the horn.   Ther is 2 or 3 inches of flat there that is just soft iron and thats so when you use a cold chisel on it the hi carbon steel of the chisel wont go flat or chip off but cut into the chisel block undamaged.   Smiths would often temper and sharpen tools for other trades people and to show thay were good thay would drive a newley reworked wood chisel or what have you right into the foot of ther anvil then pull it out and shave wood with it.   Thats why old blacksmith anvils are all cut and nicked on ther bace.   Thats also where the knife people came up with ther way to show off ther new "spaceage" metal knifes, form smiths doing even worse things to cuting tools a couple hundred years back!   Just think what we could do now if we had rembered what thay knew about things without computers in say 1902 people now cant even sharpen a kitchen knife! ::)
Andy
ADfields
Hay Noble I just rembered that you would know what a pritchel is in bull terms! ;)
Andy
Bro. Noble
Andy,
Nope, you got me there, but I'm hurtin to know.
I know what a 'bung' hole is though.  In fact, I've got a bung hole borer on my garage wall.
Thanks for the excellent lesson on anvils.  I think we'll all look at our anvils with a little more appreciation now.
I tried to describe 'shooting an anvil' on another forum before I found this one.  They chewed me out for promoting dangerous activities.  Come to think of it I remember getting hit in the head with a watermelon rind at a July 4th get to gether.  I used it to wash the thrower's head.  Could have been dangerous.  Maybe they should out-law watermelons.
Noble
ADfields
Noble
It's kinda cool to me that so much refinment went into just a hunck of metal that is the anvil.   But a teacher I am not so it was not a "lesson" just me telling what I know.   If you like that kind of story telling you should read the Foxfire books, ther great!
Well a bull has 3 mane sex parts I'm shure you know, 2 oysters and 1 pritchel.   At least thats what thay call it in Arizona cow countrey after it's been cut off (in buchering a bull or steer) and dryed.   Thay are sold as walking sticks, dog treets and used to be used in coach whips as a core befor fiberglass.   People buy them up hear all the time at the pet store from a big tub marked "bull sticks" and have no clue what it is, thay think it's just a plain old rawhide treet.   I just knew you would know this, is it called some other name in MO?
Andy
The old time bottle opener!   No bung hole=no tap=no beer! :'(   It's good to know wher the important tools are at at ALL times! ;D
Bro. Noble
Andy,
I have all of the 'Foxfire'  Books.  You are right , I do enjoy them.
No we don't call the bull's part that.  In fact this is about the most lengthy conversation I ever remember being involved in on that particular subject.
DanG's G-Grandad would have had a bung hole borer.  It's used to make the hole in a wooden keg for the stopper or spigot.  You have probably seen old T shaped wood augers with wooden handles.  This is like that except it has just a short (about 1" diameter) auger and then a cone shaped cutter and then the handle.  The farther you went in, the bigger the tapered hole.  Of course the term
bung-hole is sometimes used to describe obnoxious people.
I think you did a good job teaching even if you didn't intend to.
On the anvil that is.  I could probably survive in the dairy business without the bull lesson.  I think I would rather use a walker as one of those canes.
Noble
D._Frederick
Rick,
Any thoughts on how you are going to repair your edger?
whitepe
It looks like the edger might have to wait.
Rick came into the cubicle at work this morning
mumbling something about stopping at the local dodge dealership yesterday,  crew cab, 8 foot bed and a hemi engine. Man he sure has a bad case of pickup truck
fever.  He can't fit his wife and three kids in his Dakota
and since the cold weather's coming the kids
complain about riding in the back.
I'll keep you guys posted
 :D
Whitepe
blue by day, orange by night and green in between
Rick Schmalzried
D.
I am not sure what I am going to do yet.  I haven't gotten too worried about it as I am still looking for a power plant or material to connect it to a PTO shaft.
It appears my 2 best options are to see if I can fit flange bearings on the shaft.  If not, I probably will try to re-pour the babbet.  Next time I go back to my parents, I will look up a gentleman who has done this quite a few times (he restores old steam engines).  The other alternative I liked was using a bronze bushing.  I need to measure the shaft and see what I can do with that.
Several people have suggested pillow blocks but the only way I can see using them would be to cut out the existing cast iron supports which I don't really want to get into.  I can't move the shaft forward or backwards without lots of work due to the pressure roller above it.
Bottom line is I need to find time to work on it but I have too many irons in the fire now.  I am re-doing the kitchen (building the cabinets) and it is Christmas Gift time so the edger has gone to the back burner.  Hopefully it won't end up being a large lawn ornament. :D :D
--Rick
_
|_| .  _ |
| \ | |_ |<
