Author Topic: Stinking Ole Sickymore  (Read 7136 times)
Offline SwampDonkey
  • Large Tooth
Re: Stinking Ole Sickymore
« Reply #20 on: November 26, 2006, 04:52:03 PM »
I'm pretty sure that is just on the surface of that spalted wood. Plane off a board and you'll have the marble streaks back. ;D
Move'n on.
Offline Striker
« Reply #21 on: November 26, 2006, 05:41:13 PM »
I sealed the blanks with Bailey's end sealer. Some of my boxelder blanks are showing it too.
Offline dad2nine
  • If you aren't making mistakes, your not doing nothing
« Reply #22 on: November 26, 2006, 07:37:45 PM »
Few things I learned about turning blanks: Keep a few inches away from the pith (no blocks with pith) and keep em 6" or under in thickness. Most wood working band saws will only cut a 6" max thick chunk, they cut em round before the stick em on the lathe. Sap wood is ok, even a little bark, but it fetches less than ones that are clean (no sap / bark). Seal the entire block with Ancoseal, theres a fine line between good and spalted and rotten and no good for nothing  ::).
BIIIIIIG sickymore
Started by SAW MILLER on Sawmills and Milling
Last post October 21, 2005, 11:33:16 AM
by Fla._Deadheader
stinking tom
Started by reubenT on Sawmills and Milling
Last post January 29, 2015, 07:06:13 PM
by reubenT
Stinking Oak
Started by Qweaver on Sawmills and Milling
Last post December 03, 2018, 01:55:47 PM
by SwampDonkey
Stinking Catalytic Converter
Started by Chuck White on General Board
Last post March 03, 2012, 08:14:52 AM
by downeast
