Author Topic: 20 feet container for Klin is it OK  (Read 1911 times)
Offline alsayyed
« on: February 11, 2006, 09:56:52 PM »
Recently I have built my Klin which consists of steel tubing and covered with play wood and I think it OK.
A friend of mine asked me about 20 feet container is it suitable for drying process. What type of modification needed to improve the air circulation inside? From my own experience container gets very hot especially in the summer where temperature get around 120F.
Dose anybody experienced drying using 20 feet container.
Offline Don_Lewis
  • dry kilns, heat pumps
    • nyle
Re: 20 feet container for Klin is it OK
« Reply #1 on: February 11, 2006, 11:23:48 PM »
A refrigerated container will work but don't try to use a regular one and try adding insulation.It is less expensive to buy a reefer.
A 20' container can be used as a 2000 BF kiln
Offline Furby
  • Blurb....
« Reply #2 on: February 12, 2006, 12:12:47 AM »
I'm gonna take a guess that you are thinking about using it as a solar kiln alsayyed?
If you are, I don't see why what you already have would be too much different.
Offline isassi
  • Dis-member-ed
« Reply #3 on: February 12, 2006, 07:39:13 AM »
You know, I will get hammered for this, but if a steel box were painted flat black, in the oklahoma sun, the temps would get unreal inside. Before I understood temp control, I thought about a shipping container and simply painting it black. What i have found is a '30 long insulated moving trailer, and I think I will build a solor collector for the top and flex duct to pipe it in....I wish those containers were cheaper..I could use several.... :D
Offline Ga_Boy
  • Been rode hard and hung up wet; more than once.
« Reply #4 on: February 12, 2006, 07:58:11 AM »
Alsayyed,
I've two 20 foot containers, one is the kiln the other is used for dried material storage.
I was to have posted pictures on Friday, a big snow storm came up on here on the East Coast of the US and I spent Friday gettting ready for two days of snow fall.
I'll venture out there today and take pictures of the interrior workings of the unit.  Mine are home built using components purchased off the shelf from several vendors.   Simple stuff.
Need advice on using freight container for klin.
Started by alsayyed on Drying and Processing
Last post April 14, 2006, 08:17:38 PM
by Den Socling
Woodmizer klin
Started by steve marek on Drying and Processing
Last post July 14, 2016, 12:00:31 PM
by Tom the Sawyer
solar klin
Last post April 10, 2012, 10:00:47 PM
by treenail
Building a solar klin
Started by Moulder on Sawmills and Milling
Last post April 22, 2003, 07:55:19 AM
by Rick Schmalzried
